1 Reply Latest reply on Apr 6, 2009 9:19 AM by nikos101
    Advanced data grid icon
    nikos101 Level 2
      Hi there,
      the defualt Advanced data grid icon for a row(child of tree) is a sheet of paper. I want to change that icon if a data elements property matches a certain criteria. Is this possible?
        • 1. Re: Advanced data grid icon
          nikos101 Level 2
          This is the answer:
          itemIconsproperty
          public var itemIcons:Object
          An object that specifies the icons for the items.       Each entry in the object has a field name that is the item UID       and a value that is an object with the following format:
                {iconID: Class, iconID2: Class}
          The iconID field value is the class of the icon for       a closed or leaf item and the iconID2 is the class       of the icon for an open item.
          This property is intended to allow initialization of item icons.       Changes to this array after initialization are not detected       automatically.       Use the setItemIcon() method to change icons dynamically.
          The default value is undefined.
          See also
