• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Creating a Calander that Queries a Folder
New Here ,
Apr 06, 2009 Apr 06, 2009
I'm trying to create a calander popup that will look into a folder (rather than a db) and retrieve a file created on that date. Is this possible? If so how (I'm a noob)?
TOPICS
Advanced techniques
Views
336
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
Apr 07, 2009 Apr 07, 2009
LATEST
This is absolutely possible, but your question is a little too vague to give you specifics. You'll need to look into using the cffile tag to get the file off of disk. If we assume that your popup takes a date through the URL, and your files are formatted as "yyyy-mm-dd.txt" in a folder called "myfiles" at the sae level as your popup, then you could do something like this:
<cffile action="read" file="#ExpandPath("myfiles/#DateFormat(URL.myDate, "yyyy-mm-dd")#.txt" variable="myFileContent" />
Then, to output the content of the file:
<cfoutput>#myFileContent#</cfoutput>
You can find more information on the cffile tag here:
http://livedocs.adobe.com/coldfusion/8/htmldocs/help.html?content=Tags_f_02.html
Hope that helps,
Daniel Short
Adobe Community Expert
Message was edited by: Daniel Short. Added syntax highlighting.
Votes
Translate
Translate
Report
Report
Resources
Documentation
