1 Reply Latest reply on Apr 7, 2009 3:54 AM by Seglespaan
    Drop Shadow Filter
    Seglespaan Level 1
      is it possible to amend the following code so that it renders the drop shadow in real time. i.e. when the button is toggled and the shadow showing, when a user moves one of the sliders the shadow updates in real time??
      Cheers
      <?xml version="1.0"?>
      <!-- styles/ApplyFilterAS.mxml -->
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
          <mx:Script><![CDATA[
              import flash.filters.*;
              public function toggleFilter(distance, angle, color, alpha):void {
              trace(hSAlpha.value);
                  if (label1.filters.length == 0) {
                      /* The first four properties of the DropShadowFilter constructor are
                         distance, angle, color, and alpha. */
                      var f:DropShadowFilter = new DropShadowFilter(distance,angle,color,alpha);
                      var myFilters:Array = new Array();
                      myFilters.push(f);
                      label1.filters = myFilters;
                  } else {
                      label1.filters = null;
          ]]></mx:Script>
          <mx:Label id="label1" text="ActionScript-applied filter."/>
          <mx:Button id="b1" label="Toggle Filter" click="toggleFilter(hSdistance.value,hSAngle.value,cpShadowColour.selectedColor,hSAlpha.v alue)"/>
          <mx:HSlider id="hSdistance"
          minimum="0" maximum="20"
          snapInterval="1"
          liveDragging="false"
          enabled="true"
          labels="[0,5,10,15,20]"/>
          <mx:HSlider id="hSAngle"
          labels="[0,90,180,270,360]"
          minimum="0" maximum="360"
          snapInterval="1"
          enabled="true"
          liveDragging="true"/>
          <mx:ColorPicker id="cpShadowColour"/>
          <mx:HSlider id="hSAlpha"
          labels="[0,.25,.5,.75,1]"
          minimum="0" maximum="1"
          snapInterval=".1"
          enabled="true"
          liveDragging="true"
          value="1"/>
      </mx:Application>
        • 1. Re: Drop Shadow Filter
          Seglespaan Level 1
          Answered my Own question, Heres the solution.
                          myFilters.push(f);
                          b1.selected="true"
                  public function toggleFilter2():void {
                         toggleFilter(hSdistance.value,hSAngle.value,cpShadowColour.selectedColor,hSAlpha.value)
                      } else {
              ]]></mx:Script>
              <mx:Button id="b1" label="Toggle Filter" toggle="true" click="toggleFilter2()"/>
              snapInterval="1"
              liveDragging="true"
              enabled="true"
              change="toggleFilter(hSdistance.value,hSAngle.value,cpShadowColour.selectedColor,hSAlpha.v alue)"/>
              snapInterval="1"
              enabled="true"
              liveDragging="true"
              <mx:ColorPicker id="cpShadowColour" change="toggleFilter(hSdistance.value,hSAngle.value,cpShadowColour.selectedColor,hSAlpha. value)"/>
              snapInterval=".1"
              enabled="true"
              liveDragging="true"
              value="1"
          </mx:Application>
