6 Replies Latest reply on Apr 8, 2009 4:25 AM by hkpadobe
    Variable Scope
    hkpadobe
      I have made a variable Bindable and Public in an MXML file. How do I access this variable in the Root(main MXML) file?
        • 1. Re: Variable Scope
          nikos101 Level 2
          Hi welcome to the forum, I hope you find lots of help here and we look forward to your contributions as well
          In regards to your question, if its a child of the main file then just
          childName.variable
          Hope this helps
          Best regards
          Nikos
          • 2. Re: Variable Scope
            hkpadobe Level 1
            Hi Nikos,
            I have a 10 separate mxml files that make up my application. As in my question I need to access a variable I have created in one of the 10 files in the main mxml file. I tried your suggestion and got the following error:  1119: Access of possibly undefined property  through a reference with static type Class.
            Any clues?
            • 3. Re: Variable Scope
              nikos101 Level 2
              You need to use the id of your component, not the name of the class ie
              You have a component called Component.
              You create that component and give it an id  say     george.
              then you do george.property not Component.property
              • 4. Re: Variable Scope
                hkpadobe Level 1
                Nikos,
                Tried that and got the following error: 1120: Access of undefined property myPage2.
                In my main mxml file I have got an Import statement that imports all my Components, so not sure why this error has arisen.
                I am accessing the variable in the main mxml file in an TextInput field as follows:
                <mx:TextInput
                x="825" y="460" id="totVal" width="85" text="{myPage2.totalValue}"/>
                totalValue is a variable I have declared as Bindable and Public in another one of my mxml files, so all I want to do is access this variable in the TextInput field.
                • 5. Re: Variable Scope
                  Michael Borbor Level 4
                  Hi there, as Nikos wrote what you need is to add the component inside your mxml and give the component reference an id: for instance if in your mx:application is like this:
                  <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                        xmlns:myPage2="*">
                  Then you add any of the components you have to your mxml app file and give the component an id.
                  <myPage2:myComponent id="test" />
                  And finally you can reference the public var
                  <mx:TextInput
                  x="825" y="460" id="totVal" width="85" text="{test.totalValue}"/>
                  • 6. Re: Variable Scope
                    hkpadobe Level 1
                    Michael, Nikos
                    Thanks for your input. I have access to the variable via your sugguestions.
