0 Replies Latest reply on Apr 7, 2009 9:04 AM by slhommer
    HTTPService for remote XML file with user/password required?
      I have an application using HTTPService to access local XML files to populate databound controls.  Works great.
      Next I need to put the XML files on a remote file share.
      If the remote drive is mounted prior to running the Flex app, it works fine.
      If the remote drive is not mounted, HTTPService throws the onFault event.
      I am using <httpService>.setRemoteCredentials("<userName>","<password>","") but that does not solve it.
      When the remote drive is mounted, using setRemoteCredentials doesn't cause problems, but it doesn't solve it when not mounted either.
      Any suggestions for passing user/password credentials to a file share via HTTPService?
      Thanks in advance,
      SLH
