7 Replies Latest reply on Apr 7, 2009 3:54 PM by kglad
    External png as mask
      I have several pngs I need to load as masks. The user will be making different selections that requires
      these to be external images. I've managed to get the png working as a mask just fine when I physically
      place it on the timeline and assign cacheAsBitmap=true to both it and the mc to be masked. But when I
      try to load the png using loadMovie... it no longer behaves as a mask... any clues gents?
      Thanks in advance,
      jH
        • 1. Re: External png as mask
          did you enable the cacheAsBitmap property of the target movieclip AFTER loading was complete?
          • 2. Re: External png as mask
            Level 1
            Yes, I thought of that and made sure I set cacheAsBitmap after I loaded the png.... still no go
            • 3. Re: External png as mask
              if you set your mask and enable cacheAsBitmap AFTER loading is complete, there is no problem.
              if you think you're doing that and having a problem, copy and paste your relevant code.
              • 4. Re: External png as mask
                Level 1
                Thanks for the help kglad, I greatly appreciate it, as this has had me pulling my hair out...
                Here's the AS I'm using:
                this.createEmptyMovieClip("mask", this.getNextHighestDepth());
                mask.loadMovie("masks/sorrento_frame_mask.png");
                mask.cacheAsBitmap=true;
                color.cacheAsBitmap=true;
                color.setMask(mask);
                In the actual application I'm using nested movie clips, this is just a basic
                example I'm working with, first to see if there was a problem with the
                nested clips... which there wasn't, they worked fine as long as the
                png was physically on the timeline.
                • 5. Re: External png as mask
                  that's going to fail.  you're not waiting until AFTER loading is complete to apply setMask() and enable cacheAsBitmap:
                  this.onEnterFrame = loadProgressF;
                  function loadProgressF(){
                  if(mask.getBytesLoaded()>0&&mask.getBytesLoaded()>=mask.getBytesTotal()){
                  color.cacheAsBitmap=true;  // this can be done before loading is complete, but not the other lines of code
                  delete this.onEnterFrame;
                  • 6. Re: External png as mask
                    Level 1
                    Thanks man, I see what I was doing wrong now. I actually wound up using the MovieClipLoader class with a listener
                    and that did the trick. Thanks again for your help!
                    jH
                    • 7. Re: External png as mask
                      you're welcome.
