12 Replies Latest reply on Apr 7, 2009 6:04 PM by Kodebuster
    VirtualDub to DV-AVI ~ Red Line...
    Kodebuster Level 3
      Using VDub to DV-AVI before loading into PE4, I noticed that my converted file had the infamous 'Red Line' above it, suggesting it should be rendered for better viewing (and workflow).
      How I got here is not pretty, but I'll give you the workflow:
      An old analog tape to Sony Mini-DVD Handycam.
      Export from Handycam as Mpeg2.
      Mpeg2 to Windows Movie Maker (WMM).
      Export from WMM as DV-AVI type I
      DV-AVI to VDub, output as DV-AVI II.
      The reason I don't go Mpeg2 to VDub is I get a constant Audio Compression error, so I goto WMM first.
      Surprisingly, this seems to work fine and the vid/audio quality is acceptabe (considering where I started).
      Because of the 'Red Line', the monitor view within PE is ugly, but Burn to Folder and play is okay (no jerk or sync issue).
      I don't recall seeing Red on DV-AVI from VDub in the past, and was wondering if others witness the same (or maybe it's my weird workflow on Assets for this Project)...
