5 Replies Latest reply on Apr 9, 2009 3:35 PM by Günter Schenk
    shopping cart won't render on remote server
    JBWebWorks Level 1
      Building a shopping cart using dreamweaver cs4 and eCart4 from Web Assist
      built a products page, detail page and cart page; not finished with the checkout pages.
      works fine on my testing server but when i uploaded to remote server the pages will not render in any browser.
      I am not sure if it is a coding issue or a setting on my remote server that is incorrect.
      If it was a coding issue, i would think i would get the same from the testing server?
      products page is
      http://www.markwatsoncarvings.com/canes.php
      if i need to attach the code, please let me know.
      thanks for your help,
      jim balthrop
        • 1. Re: shopping cart won't render on remote server
          Günter Schenk Level 4
          Hi Jim,
          as these forums are focused on the Adobe Dreamweaver Developer Toolbox (ADDT) - extension and its usage, I suggest posting your question in the WebAssist product forums.
          Cheers,
          Günter
          • 2. Re: shopping cart won't render on remote server
            JBWebWorks Level 1
            thanks Gunter
            i have put in a tech support ticket with web assist, but posted to dreamweaver just in case someone might have an answer.
            i put in  a PHP code at line one of the page to show errors
            get errors
            Warning: main() [function.main]: open_basedir restriction in effect. File(/WA_eCart_Definition_PHP.php) is not within the allowed path(s): (/var/www/vhosts/markwatsoncarvings.com/httpdocs:/tmp) in /var/www/vhosts/markwatsoncarvings.com/httpdocs/WA_eCart/markwatsonCart_PHP.php on line 2 Warning: main(WA_eCart_Definition_PHP.php) [function.main]: failed to open stream: Operation not permitted in /var/www/vhosts/markwatsoncarvings.com/httpdocs/WA_eCart/markwatsonCart_PHP.php on line 2 Warning: main() [function.main]: open_basedir restriction in effect. File(/WA_eCart_Definition_PHP.php) is not within the allowed path(s): (/var/www/vhosts/markwatsoncarvings.com/httpdocs:/tmp) in /var/www/vhosts/markwatsoncarvings.com/httpdocs/WA_eCart/markwatsonCart_PHP.php on line 2 Warning: main(WA_eCart_Definition_PHP.php) [function.main]: failed to open stream: Operation not permitted in /var/www/vhosts/markwatsoncarvings.com/httpdocs/WA_eCart/markwatsonCart_PHP.php on line 2 Warning: main() [function.include]: Failed opening 'WA_eCart_Definition_PHP.php' for inclusion (include_path='.:.:') in /var/www/vhosts/markwatsoncarvings.com/httpdocs/WA_eCart/markwatsonCart_PHP.php on line 2 Fatal error: Class 'WA_eCartDefinition' not found in /var/www/vhosts/markwatsoncarvings.com/httpdocs/WA_eCart/markwatsonCart_PHP.php on line 3
            • 3. Re: shopping cart won't render on remote server
              JBWebWorks Level 1
              i was told that
              the error: open_basedir restriction in effect indicates that the open_basedir setting in the php.ini is turned on which is used to restrict the locations that include files can be placed on the server.
              • 4. Re: shopping cart won't render on remote server
                JBWebWorks Level 1
                sorry, Gunter
                I realize now that i was in the wrong place even on the Dreamweaver forums. I have not gotten used to the new forum look. All i saw was PHP and dove right in.
                thanks again
                jim
                • 5. Re: shopping cart won't render on remote server
                  Hi Jim,
                  sorry, Gunter
                  no need to excuse ;-) Guess what, the new forums seem to confuse lots of regular Dreamweaver users for this very reason, and the ADDT forums currently get an increasing number of unrelated posts in the PHP/ASP/ColdFusion Development subforums due to the somewhat misleading links on the main Dreamweaver forums page. Hope this will change soon, and I already called Adobe´s forum admins attention to this issue.
                  Cheers,
                  Günter
