1 Reply Latest reply on Apr 8, 2009 8:02 AM by RossRitchey
    Loader Problem
      Dear Friend,
      I am Shabir Gilkar from Srinagar Kashmir working as web Designer in a IT company based in Srinagar Kashmir. I am fresher to the Flash and currently i am learning the Flash. I designed the Loader and Intro and the copy of which i am attaching with this post. Basically my loader is not working finely as per the requirements. Basically i have given the loader fluid filling effect, but at the 46-47% it goes full filled and then start again. Please take a look and suggest me the troubleshoot. Below given is the code i have written in the action script.
      stop();
      var yStart = 255;
      var yChange = 77;
      var myInterval = setInterval (preload,100);
      function preload () {
          var current = _root.getBytesLoaded();
          var total = _root.getBytesTotal();
          var pctload = Math.round(current/total*100);
           Pct_txt.text = pctload;
          Mask_mc._y = yStart - yChange/100*pctload;
          if (current >= total) {
              gotoAndStop ("Intro",1)
              clearInterval(myInterval);
      Regards
      Shabir Gilkar
        • 1. Re: Loader Problem
          RossRitchey Level 4
          Something funky seems to be going on with the formula.  My first guess is its an ordering issue.  The formula should probably look like:
          Mask_mc._y = yStart - (yChange/100)*pctload; - which will change the order the pieces are executed in.
          But that may not be absolutely correct anyways.
          An easier method, and the way I typically do this type of effect, is to make the text a MovieClip.  Use timeline animations inside that movieClip to animate the fill over 100 frames.  Put a stop() in the first frame.  And then, the code would look like:
              LoaderClip.gotoAndStop(pctload);
          So, the animation is flawless, because it is timeline-based, not code based.  No formulas to figure out, just find the percent, and send the animation to that frame.
