17 Replies Latest reply on Jul 10, 2009 8:28 AM by Kasyan Servetsky
    VBScript Working with layers
    Eliane_Yanou Level 1
      Hello everybody!
      I would like to use a script to work whith layers in InDesign CS3 but I can't find any reference for VBS.
      The only one I have is "Set myLayer = myDocument.Layers.Add" to add a new layer. But, how to delete one or import one from another file, i.e. ?
      Who can help me? Many thanks in advance!
      Eliane
        • 1. Re: VBScript Working with layers
          Tony Tuneson Level 1
          Yes, documentation for the latest versions would be nice. For now, see the Layer Methods in the InDesign Scripting Guide for CS2 and  a separate document abourt changes in CS3 (nothing to do with Layers, but a must-read).
          http://www.adobe.com/products/indesign/pdfs/InDesign_Scripting_Guide.pdf
          http://wwwimages.adobe.com/www.adobe.com/products/indesign/scripting/pdfs/indesign_cs3_scr ipting_read_me.pdf
          You could use an Object Browser that shows all available properties and methods (already shown in earlier posts):
          http://www.teusdejong.nl/indesign/IDBrowser.zip
          There is no import method for layers. To copy a layer from another document, I use a simple method. The script tells to open both target and source document, turn on 'remember layers when copying', make only layers to copy visible. Cycle through all speads with the following: go to source doc/spread, selectall objects, copy, paste in place to target doc/spread.
          Tony
          • 2. Re: VBScript Working with layers
            Thanks for the links!
            I already found a scripting documentation for CS3 under http://wwwimages.adobe.com/www.adobe.com/products/indesign/scripting/pdfs/InDesignCS3_Scri ptingGuide_VB.pdf but it's not so complete.
            Furthermore in Introduction to scripting (http://wwwimages.adobe.com/www.adobe.com/products/indesign/scripting/pdfs/Adobe_Intro_to_S cripting1.pdf) there is an explanation how to view the VBS object library in any Microsoft Office Application. But the Object Browser you mentioned may be more convinient to use.
            Well, I now have some to study and will try to find out the correct syntax!
            • 3. Re: VBScript Working with layers
              With the correct tools it doesn't take too long to find what you are looking for. Finally, to delete a layer use: myDocument.ActiveLayer.Delete.
              Tony, I will follow your tip for the "import" of a layer through the copy procedure. Many thanks for your quick help!!!
              Eliane
              • 4. Re: VBScript Working with layers
                Please disregard this message (att. too large), see the next one.
                Message was edited by: Tony Tuneson
                • 5. Re: VBScript Working with layers
                  You need the Scripting Reference, not only the Guide.
                  I can't find it anymore on the Net quickly, so I made link for you:
                  https://www.clickanad.com/download/InDesign_Script_Model.zip
                  Filesize: 7,31 MB. This file will be downloadable until Wednesday, 22 April 2009
                  Good luck
                  T
                  • 6. Re: VBScript Working with layers
                    Hi Tony,
                    sorry, but I'm still working on the script to copy a layer from another document. I guess I'm almost done, but I still can't find the proper syntax to select all objects of the layer... Could you help me? Sorry, I'm quite new in wrinting scripts for InDesign!
                    Many thanks in advance.
                    Eliane
                    • 7. Re: VBScript Working with layers
                      This is what woked for me; I can see some things that I would do differently now, but it works.
                      It's in VB6, not too different from your VBS, I hope.
                      Sub CopyLayers(IDSource As InDesign.Document, IDTarget As InDesign.Document)
                      Dim i As Long
                      Dim j As Long
                      Dim PageName As String
                      Dim theLayoutWindow As InDesign.LayoutWindow
                      Dim mySpread As InDesign.Spread
                      Dim SelCounter As Long
                      Dim LayerFound As Boolean
                      Dim myLayer As InDesign.Layer
                      Dim itemCount As Long
                      For i = 0 To LayerList.ListCount - 1
                          For j = 1 To IDSource.Layers.Count
                              If LayerList.List(i) = IDSource.Layers.Item(j).Name Then
                                  IDSource.Layers.Item(j).Visible = LayerList.Selected(i)
                                  If LayerList.Selected(i) Then
                                      LayerFound = True
                                  End If
                              End If
                          Next j
                      Next i
                      myIndesign.ClipboardPreferences.PasteRemembersLayers = True
                      If Not LayerFound Then
                          MsgBox "No Layer selected. Exiting."
                          Exit Sub
                      End If
                      For j = 1 To IDTarget.Layers.Count
                          IDTarget.Layers.Item(j).Visible = False
                          DoEvents
                          Sleep (50)
                          DoEvents
                      Next j
                          LayerFound = False
                              If LayerList.List(i) = IDTarget.Layers.Item(j).Name Then
                                  If LayerList.Selected(i) = True Then
                                      IDTarget.Layers.Item(j).Visible = True
                                      DoEvents
                                      Sleep (50)
                                      DoEvents
                                  End If
                                  LayerFound = True
                              End If
                          Next j
                          If (Not LayerFound) And LayerList.Selected(i) Then
                              Set myLayer = IDTarget.Layers.Add
                              myLayer.Name = LayerList.List(i)
                          End If
                      Next i
                      For i = IDSource.Spreads.Count To 1 Step -1
                          DoEvents
                          If CopyImagesBTN.Caption = "Start" Then
                              MsgBox "User aborted."
                              Exit For
                          End If
                          Set mySpread = IDSource.Spreads.Item(i)
                          Set theLayoutWindow = myIndesign.LayoutWindows.Item(1)
                          myIndesign.ActiveDocument = IDTarget
                          ZoomTo IDTarget.Spreads.Item(i)
                          myIndesign.ActiveDocument = IDSource
                          ZoomTo IDSource.Spreads.Item(i)
                          IDSource.Select InDesign.idSelectAll.idAll, idReplaceWith
                          If IDSource.Selection.Count > 0 Then
                              myIndesign.Copy
                              Set mySpread = IDTarget.Spreads.Item(i)
                              IDTarget.Select idSelectAll.idAll, idReplaceWith
                              For itemCount = IDTarget.Selection.Count To 1 Step -1
                                  IDTarget.Selection.Item(itemCount).Locked = False
                                  IDTarget.Selection.Item(itemCount).Delete
                              Next itemCount
                              myIndesign.PasteInPlace
                              IDTarget.Select idNothingEnum.idNothing
                          End If
                      Next i
                      End Sub
                      • 8. Re: VBScript Working with layers
                        Hi Tony,
                        many thanks for your script! Unfortunately the VBScript syntax is slightly different from Visual Basic. I used to write in VBA for Microsoft Word and now started with VBScript, but I never wrote in Visual Basic. Since my script is almost finished and is a part of a bigger one, I would like to have it completely in VBScript.
                        The command I'm looking for corresponds to your "IDSource.Select InDesign.idSelectAll.idAll, idRepplaceWith". I think, the best thing is to post a new thread asking for the syntax to select all objects in VBScript (which I will do in a few minutes).
                        Again many thanks for your help!
                        Eliane
                        • 9. Re: VBScript Working with layers
                          AdobeScripts Level 3
                          but you will lose links between TextFrames in Story ...
                          robin
                          www.adobescripts.co.uk
                          • 10. Re: VBScript Working with layers
                            syntax is exactly the same the one difference I found is with For...To...Next - in VB6 (not VB.Net) you need to add variable name after Next - in VBS you should leave Next alone
                            robin
                            • 11. Re: VBScript Working with layers
                              OK, I will have to check that when I will be finished with the first part...
                              Tanks!
                              Eliane
                              • 12. Re: VBScript Working with layers
                                Hi Robin,
                                I also already found out that in VBS you should leave Next alone in the For...To...Next loop. But this is not the only thing as "select all object" didn't work neither... But we are discussing this point in another thread.
                                Anyhow, I will let you now when I find the solution!
                                Eliane
                                • 13. Re: VBScript Working with layers
                                  you have nothing to check I'm not guessing
                                  you will lose your threading - if Story is on different spreads
                                  as workaround - you need to mark (by Label) all TextFrames in Story and recreate linked order
                                  robin
                                  • 14. Re: VBScript Working with layers
                                    That's a fact. If the doc is not too large, you could set all pages as a big spread first, and do one big select copy/paste.
                                    Message was edited by: Tony Tuneson; removed "Or label the linked textframes and relink them after copying."
                                    • 15. Re: VBScript Working with layers
                                      OK, I must admit that I don't know InDesign very well since I'm not creating the documents myself...
                                      What I meant is that I will have to check how the docs are made and will have to find a compromise depending on the structure of the documents.
                                      But you gave me very valuables tips how to try to find a solution. Thanks!
                                      Eliane
                                      • 16. Re: VBScript Working with layers
                                        mcolmenero Level 1
                                        I wan to count how many layers have in a indesign document.
                                        What does the code to make this? I need in javascript. Could you help me please?
                                        I write this code, but is not correct.
                                        var n=app.activeWindow.Layers.count;
                                        alert("Layers is " + n);
                                        Thanks.
                                        • 17. Re: VBScript Working with layers
                                          Kasyan Servetsky Level 5
                                          var myLayersCount = myDoc.layers.length;
                                          var myMessage = (myLayersCount == 1)?"There is 1 layer in the document.":"There are " + myLayersCount + " layers in the document."
                                          alert(myMessage);
