7 Replies Latest reply on Oct 23, 2008 11:27 AM by JaneRoberts
    Full Motion
    JaneRoberts
      Hi. I'm new to Captivate and just created a movie by importing a Powerpoint presentation and recording my script for each slide. I wanta it to run continuously from one slide to the next without the viewer having to click the mouse in between slides. There is probably a simple and obvious way to do this, but I have yet to find it. I figured asking someone might be the quickest solution. Can anyone help me?
      Thanks!
        • 1. Re: Full Motion
          Welcome to our community, Jane
          When you import the slides from PowerPoint, you have two options. One is for creating slides as Animations or Background images. The other is for allowing playback to "Advance slide" "On mouse click or Automatically". Sounds like you need to choose the option for Advancing the slides Automatically.
          Cheers... Rick
          • 2. Re: Full Motion
            JaneRoberts Level 1
            Hi Rick,
            Cool! Thanks for the immediate response. ...
            I thought I might have to go back to the drawing board and start with Powerpoint...
            If I re-import the slides, will I be able to re-use the recording I already made? Seems like I read that I could...will it be a one screen at a time process or can I do it in one fell-swoop?
            Thanks so much for your assistance!
            Jane
            • 3. Re: Full Motion
              Hi Jane
              You know, in your case it may be a pretty simple process to just edit one of the Click Box objects on any of the slides and remove the pause. Then choose the "Apply to all" function to turn it off.
              Cheers... Rick
              • 4. Re: Full Motion
                JaneRoberts Level 1
                Okay...So, I figured out how to use the Library...But now my question is this: When I drag the audio clip onto my slide...it no longer displays in the edit view the way it did in the original video. How do I edit the clip?
                • 5. Re: Full Motion
                  JaneRoberts Level 1
                  • 6. Re: Full Motion
                    JaneRoberts Level 1
                    OHHHH! Wow. That's an idea. I'll try it. THANKS.
                    • 7. Re: Full Motion
                      JaneRoberts Level 1
                      That's it! You solved it. It works! You're a genius. Thank you, Rick. BRILLIANT. Whew. You just saved me Hours of work.
