5 Replies Latest reply on Nov 3, 2009 5:10 AM by levancho
    Loading A Single XML Node Into ArrayCollection Fails?
    FlexAce Level 1
      I am loading some XML (From a HTTPService) into an ArrayCollection
              toIPipelineSumAC =  evt.result.toIPipe.sum as ArrayCollection;
      Usually the XML will contain multiple sum nodes. That all works fine
      But when there is only one node, the ArrayCollection, which I use as the data source for a data grid, is empty.
      What do I need to differently if there is only a single node?
      Mathias
