5 Replies Latest reply on Apr 10, 2009 7:49 AM by Handycam
    Naming components created in a loop?
    Handycam Level 1
      I asked this once before, but none of the answers work in this case.
      I am creating a series of components as children of a viewstack based on XML loaded.  I am looping through the XML and instancing a component for each node.
      private function createSteps():void{
      var stepNumber:uint = 1;
      var numSteps:uint = dataXML.length;
              for each(var step:XML in dataXML){
      var recipeStep:CyorStep = new CyorStep();
      mainViewStack.addChild(recipeStep);
      recipeStep.label = stepNumber +". "+ step.stepTitle;
      recipeStep.itemChoicesList = step..item;
      recipeStep.prompt.text = step.prompt;
      recipeStep.stepCaption.text = step.bodyText;
      recipeStep.stepTitle.text = step.stepTitle;
      if (stepNumber == numSteps){
      recipeStep.nextBtn.label = "FINISH";
      recipeStep.addEventListener("GO_PREVIOUS",prevStep);
      recipeStep.addEventListener("GO_NEXT",nextStep);
      stepNumber++
      The problem is all these objects have randomly generate names.  How can I assign each object a name as I instance it, as in:
      var recipeStep1:CyorStep = new CyorStep();
      var recipeStep2:CyorStep = new CyorStep();
      and so on?
        • 1. Re: Naming components created in a loop?
          Gregory Lafrance Level 6
          Define the constructor to take a parameter, and set this.name and/or super.name. But I don't think you can do this in MXML, so implement the compoenent as an AS class.
          • 2. Re: Naming components created in a loop?
            Handycam Level 1
            Wouldn't I still have the same naming and scoping problem?
            // Create and add steps
            var recipeStep:CyorStep = new CyorStep("step"+stepNumber);
            If I did that could I
            1. Give it a sequential name somehow
            2. Be able to access it OUTSIDE of this function
            • 3. Re: Naming components created in a loop?
              I think in that case you would need to put the instances in some storage mechanism outside the function, like a collection or object. If the names are unique, you could use an associative array object:
              myStorageObj[myStepObj1Name] = mysStepObj1;
              myStorageObj[myStepObj2Name] = mysStepObj2;
              • 4. Re: Naming components created in a loop?
                Handycam Level 1
                OK, close.  What I have done is created an array to hold them:
                [Bindable]
                public var stepModules:Array = [];
                Then modified my creation loop like this:
                var recipeStep:CyorStep;
                //var recipeStep:CyorStep = new CyorStep();
                recipeStep = new CyorStep();
                recipeStep.name = "recipeStep"+stepNumber.toString();
                ...etc...
                stepModules.push(recipeStep);
                stepNumber++;
                        trace(stepModules[0].stepCaption.text);
                This trace statement gives me the caption of the first item created, fine.  However, I have a datagrid that needs to be updated with the contents of the "drop" datagrid of the drag-n-drop in the component, so I tried setting its dataprovider to dataProvider="{stepModules[0].chosenList.dataProvider}" but I get nothing.  I can't figure out why, or if there's a step I need to do to get the dropped items to appear in the second grid as well as where they're dropped.
                • 5. Re: Naming components created in a loop?
                  Handycam Level 1
                  As an addendum, if I replace that trace statement with:
                  trace(stepModules[2].chooseList.dataProvider);
                  I get
                  <item sn="potatoes" ln1="Potatoes" ln2="new potatoes, cut into medium dice" qty="1" units="lb."/>
                  <item sn="egg noodles" ln1="Egg noodles" ln2="egg noodles" qty="2" units="cups"/>
                  <item sn="white beans" ln1="White beans" ln2="15-1/2 or 16-oz. cans white beans, drained and rinsed" qty="2" units=""/>
                  <item sn="chickpeas" ln1="Chickpeas" ln2="15-1/2 or 16-oz. cans chickpeas, drained and rinsed" qty="2" units=""/>
                  <item sn="hominy" ln1="Hominy" ln2="15-1/2 or 16-oz. cans hominy, drained and rinsed" qty="2" units=""/>
                  <item sn="rice" ln1="Long-grain white rice" ln2="long-grain white rice" qty="1/3" units="cup"/>
                  <item sn="rice" ln1="Basmati rice" ln2="basmati rice" qty="1/3" units="cup"/>
                  <item sn="orzo" ln1="Orzo" ln2="orzo pasta" qty="1/3" units="cup"/>
                  which is correctly the contents of the left (drag from) list.
                  However, trace(stepModules[2].chooseList.dataProvider.@sn) throws an error Error: Unknown Property: 'sn'.
