0 Replies Latest reply on Apr 9, 2009 11:14 AM by EricaMafnas
    How to make RH use the filename as the topic ID?
      I'm trying to generate a map file for the context-sensitive help. The information in RoboHelp says, "The program assigns the topic title or filename as the topic ID and assigns a map number."
      When I generate the map file, the topic title is being used as the topic ID in the map file.  I want to use the filename instead.  Do you know how to make RH use the filename as the topic ID?  RH says that is possible, but does not explain how to make this happen.
