2 Replies Latest reply on Apr 9, 2009 3:12 PM by iSyndicate
    Populating ComboBox with XML data
    iSyndicate
      Hi there,
      Probably the most basic question, but I'm having a hard time with this...
      Trying to populate the ComboBox with XML data as a dataProvider.
      Here is the code snippet:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                      layout="vertical"
                      creationComplete="baseDataRequest.send()">
          <mx:Script>
              <![CDATA[
                  import mx.collections.XMLListCollection;
                  import mx.rpc.events.ResultEvent;
                  [Bindable]
                  private var baseDataXML:XML;
                  private function baseResultHandler(event:ResultEvent):void
                      baseDataXML = event.result.node.child as XML;
          </mx:Script>
          <mx:HTTPService id="baseDataRequest"
                          useProxy="false"
                          resultFormat="e4x"
                          result="baseResultHandler(event)"
                          url="XML_URL"/>
          <mx:ComboBox id="comboDemo"
                       width="390"
                       dataProvider="{baseDataXML}"
                       labelField="NodeName"/>
      </mx:Application>
      And that returns nothing, basically. I know the XML is being pulled, because if I do this:
      baseDataXML = event.result as XML;
      then I just see a single item in my ComboBox, with full XML content.
      How do I populate the ComboBox with XML contents?
      XML example:
      <root>
          <node>          <child>Child1</child>
                <child>Child2</child>
           </node>
      </root>
      Question: how do I populate the ComboBox with XML data nodes? I need <child> content to be the labelField of each combo box item...
      Thanks!
      K
        • 1. Re: Populating ComboBox with XML data
          Brent Lamborn Level 2
               <mx:Script>
                    <![CDATA[
                         var baseDataXML:XML = <root><node><child>Child1</child><child>Child2</child></node></root>;
               </mx:Script>
                           width="390"
                           dataProvider="{baseDataXML.node.child}"
          Don't do:
          Instead just do:
          baseDataXML = XML(event.result);
          And in your combo:
          • 2. Re: Populating ComboBox with XML data
            iSyndicate Level 1
            Thanks for your reply!
            Apparently, the problem I was having was related to namespaces... I had a namespace declaration in the root node of my XML and it was breaking the whole thing. Once that is no longer there - problem is gone!
