4 Replies Latest reply on Apr 10, 2009 3:26 PM by 123qweads
    ArrayCollection & AddEventListener: error 1006
    123qweads
      HI..
      in order to handler some custom components (usuallyCanvas) I need to put them in an ArrayCollection....
      the problem is that a this point I can't use AddEventListener on AC objects.....
      myArrayCollection[index].AddEventListener give me the error nr. 1006...
      because AddEventListener is not a method for myArrayCollection[index]
      someone can help me?
      questa soluzione http://www.gongon2.com/flex/pippo/bin/OrizListOL.html non posso usarla...
      now I show you how make AC, maybe error is here...
      Codice:
      import com.myComponents.*;
      private function LoadInterfaces():void {
           myArrayCollection.addItemAt( FirstMenu, 0 );
           myArrayCollection.addItemAt( SecondMenu, 1 );
           myArrayCollection.addItemAt( ThirdMenu, 2);
      in com.myComponents there are Firs Second e Third menu, of course
      bye and thanks for aids
        • 1. Re: ArrayCollection & AddEventListener: error 1006
          Michael Borbor Level 4
          Hi there, if you want to handle components you should add the event listener to the components, why do you want to add a listener to the AC? Even though you could use setters  to have some sort of awareness over the ac changes.
          • 2. Re: ArrayCollection & AddEventListener: error 1006
            Gregory Lafrance Level 6
            Menu(myArrayCollection[index].AddEventListener(.........));
            where Menu is whatever type you are dealing with (need to know in advance).
            • 3. Re: ArrayCollection & AddEventListener: error 1006
              ergo_eleven Level 1
              You problem is that you trying to assign event listener to an object that does not an IEventDispatcher.
              Consider example:
              public function init():void
                  var ac : ArrayCollection = new ArrayCollection([1, 2, 3]);
                  ac[1].addEventListener("click",
                      function (event : MouseEvent) : void
                          trace("on click");
              It fails with error 1006, because 2 (object of Nuber) is not implements intreface IEventDispatcher.
              Run this one:
                  var b1 : Button = new Button();
                  var b2 : Button = new Button();
                  var b3 : Button = new Button();
                  addChild(b1);
                  addChild(b2);
                  addChild(b3);
                  var ac : ArrayCollection = new ArrayCollection([b1, b2, b3]);
                          trace("on click");
              In debug mode when you'll press on second button will see "on click" message in console.
              So everything is ok.
              Good luck!
              • 4. Re: ArrayCollection & AddEventListener: error 1006
                123qweads Level 1
                @Michael Borbor
                Because, I must add and remove differents effect listener... so I want handle my menu  only a structure, myArrayCollection
                @Greg Lafrance
                Thank but doesn't work.... I've tried with DisplayObject but cast give me an error...
                cast in Object works, but Object has not AddEventListener
                @ergo_eleven
                You problem is that you trying to assign event listener to an object that does not an IEventDispatcher. [omissis]
                Yes, you have hit the target,
                but I prefered don't create a new istance.....
                but if this is the only way, I'll walk it...
                Thanks at all three for your advice!
