0 Replies Latest reply on Sep 10, 2008 12:33 AM by timpano
    Spry drop down menu gone crazy
    timpano
      I created a menu bar with Spry and it works fine in Firefox but playing up in IE. The drop down menu starts displaying from the top of the page and not where the menu bar is. I have never come across this issue with Spry and cannot figure out whats wrong. the page is www.cerdomustile.com.au/new if you want to have a look. the Spry code is:
      @charset "UTF-8";
      /* SpryMenuBarHorizontal.css - version 0.6 - Spry Pre-Release 1.6.1 */
      /* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
      LAYOUT INFORMATION: describes box model, positioning, z-order
      /* The outermost container of the Menu Bar, an auto width box with no margin or padding */
      ul.MenuBarHorizontal
      margin: 0;
      padding: 0;
      list-style-type: none;
      font-size: 11px;
      cursor: default;
      width: 500px;
      background-color: #000000;
      font-weight: normal;
      font-family: "Trebuchet MS";
      height: 18px;
      /* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
      ul.MenuBarActive
      z-index: 1000;
      /* Menu item containers, position children relative to this container and are a fixed width */
      ul.MenuBarHorizontal li
      margin: 0;
      padding: 0;
      font-size: 11px;
      position: relative;
      text-align: left;
      cursor: default;
      width: 100px;
      float: left;
      height: 18px;
      /* Submenus should appear below their parent (top: 0) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
      ul.MenuBarHorizontal ul
      margin: 0;
      padding: 0;
      font-size: 100%;
      z-index: 1020;
      cursor: default;
      width:100px;
      position: absolute;
      left: -1000em;
      height: 18px;
      /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to auto so it comes onto the screen below its parent menu item */
      ul.MenuBarHorizontal ul.MenuBarSubmenuVisible
      left: auto;
      height: 18px;
      position:absolute
      /* Menu item containers are same fixed width as parent */
      ul.MenuBarHorizontal ul li
      width: 100px;
      /* Submenus should appear slightly overlapping to the right (95%) and up (-5%) */
      ul.MenuBarHorizontal ul ul
      position: absolute;
      margin: -5% 0 0 95%;
      /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
      ul.MenuBarHorizontal ul.MenuBarSubmenuVisible ul.MenuBarSubmenuVisible
      left: auto;
      top: 0;
      DESIGN INFORMATION: describes color scheme, borders, fonts
      /* Submenu containers have borders on all sides */
      border: 1px solid #CCC;
      /* Menu items are a light gray block with padding and no text decoration */
      ul.MenuBarHorizontal a
      display: block;
      cursor: pointer;
      padding: 0.5em 0.75em;
      color: #FFFFFF;
      text-decoration: none;
      /* Menu items that have mouse over or focus have a blue background and white text */
      ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus
      color: #FFF;
      /* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
      ul.MenuBarHorizontal a.MenuBarItemHover, ul.MenuBarHorizontal a.MenuBarItemSubmenuHover, ul.MenuBarHorizontal a.MenuBarSubmenuVisible
      color: #625647;
      SUBMENU INDICATION: styles if there is a submenu under a given menu item
      /* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
      background-repeat: no-repeat;
      background-position: 95% 50%;
      ul.MenuBarHorizontal ul a.MenuBarItemSubmenu
      /* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a "hover" background image positioned on the far left (95%) and centered vertically (50%) */
      ul.MenuBarHorizontal ul a.MenuBarItemSubmenuHover
      BROWSER HACKS: the hacks below should not be changed unless you are an expert
      /* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
      ul.MenuBarHorizontal iframe
      position: absolute;
      z-index: 1010;
      filter:alpha(opacity:0.1);
      /* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
      @media screen, projection
      ul.MenuBarHorizontal li.MenuBarItemIE
      display: inline;
      f\loat: left;
      background: #FFF;
