11 Replies Latest reply on Oct 10, 2009 9:40 PM by abdul_jazzix
    mp3 player not working after being embedded
    abdul_jazzix
        Hello guys,
      I have a player for sound files (Fabricio Zuardi) which is very nice, easy to work with and easy to texturize.
      It works with a xml list.
        What I did was to load the swf file of the player into my main file of the website (also flash).
      The thing is that i can see the titles of the songs but the player won't work.
      Here's the as file.
        Can anybody give me a hint?
        I tghought it was a location problem at the beginning but i don't think it was. I tried all the possibilities.
         Thank you
      repeat_playlist = true;
      //playlist_size = 3;
      //player_title = "customizeable title test"
      //song_url = "media/Akropola.mp3";
      //song_title = "Imperial Teen - Ivanka";
      autoload=true
      autoplay=true
      playlist_url = "playlist.xml"
      //info_button_text = "Buy Album"
      //playlist_url = "http://hideout.com.br/shows/radio-test.xspf";
      //playlist_url = "http://cchits.ning.com/recent/xspf/?xn_auth=no";
      //radio_mode = true;
      stop();
      //constants
      DEFAULT_PLAYLIST_URL = "playlist.xml";
      DEFAULT_WELCOME_MSG = "Hideout XSPF Music Player - by Fabricio Zuardi";
      LOADING_PLAYLIST_MSG = "Loading Playlist...";
      DEFAULT_LOADED_PLAYLIST_MSG = "- click to start"
      DEFAULT_INFOBUTTON_TXT = "Track Info"
      //default playlist if none is passed through query string
      if(!playlist_url){
          if(!song_url){
              playlist_url = DEFAULT_PLAYLIST_URL;
          }else{
              single_music_playlist = "<?xml version=\"1.0\" encoding=\"UTF-8\"?><playlist version=\"1\" xmlns = \"http://xspf.org/ns/0/\"><trackList>";
              single_music_playlist += "<track><location>"+song_url+"</location><annotation>"+song_title+"</annotation></track>"
              single_music_playlist += "</trackList></playlist>"
      //info button
      info_mc._visible=false;
      if(!info_button_text){
          info_button_text = DEFAULT_INFOBUTTON_TXT;
      //variables initialization
      playlist_array = [];
      track_index = 0;
      volume_level = 100;
      pause_position = 0;
      playlist_xml = new XML();
      playlist_xml.ignoreWhite = true;
      playlist_xml.onLoad = playlistLoaded;
      mysound = new Sound(this);
      playlist_listener = new Object();
      playlist_list.addEventListener("change", playlist_listener)
      //play_btn.onPress = playTrack;
      //functions
      //xml parser
      function playlistLoaded (success){
          if(success){
              var root_node = this.firstChild;
              for(var node = root_node.firstChild; node != null; node = node.nextSibling){
                  if(node.nodeName == "title"){
                      playlist_title = node.firstChild.nodeValue;
                  if(node.nodeName == "trackList"){
                      //tracks
                      var tracks_array = [];
                      for(var track_node = node.firstChild; track_node != null; track_node = track_node.nextSibling){
                          var track_obj = new Object()
                          //track attributes
                          for(var track_child = track_node.firstChild; track_child != null; track_child = track_child.nextSibling){
                              if(track_child.nodeName=="location"){
                                  track_obj.location = track_child.firstChild.nodeValue
                              if(track_child.nodeName=="image"){
                                  track_obj.image = track_child.firstChild.nodeValue
                              if(track_child.nodeName=="title"){
                                  track_obj.title = track_child.firstChild.nodeValue
                              if(track_child.nodeName=="creator"){
                                  track_obj.creator = track_child.firstChild.nodeValue
                              if(track_child.nodeName=="annotation"){
                                  track_obj.annotation = track_child.firstChild.nodeValue
                              if(track_child.nodeName=="info"){
                                  track_obj.info = track_child.firstChild.nodeValue
                          track_obj.label = (tracks_array.length+1) +". ";
                          if(track_obj.title) {
                              if(track_obj.creator) {
                                  track_obj.label += track_obj.creator+' - ';
                              track_obj.label += track_obj.title;
                          } else {
                              track_obj.label += track_obj.annotation;
                          tracks_array.push(track_obj)
              playlist_array = tracks_array;
              if(!playlist_size) playlist_size = playlist_array.length;
              if(autoplay){
                  loadTrack()
              }else{
                  start_btn_mc.start_btn.onPress = loadTrack;
                  track_display_mc.display_txt.text = playlist_title+" "+DEFAULT_LOADED_PLAYLIST_MSG;
                  if(track_display_mc.display_txt._width>track_display_mc.mask_mc._width){
                      track_display_mc.onEnterFrame = scrollTitle;
                  }else{
                      track_display_mc.onEnterFrame = null;
                      track_display_mc.display_txt._x = 0;
          }else{
              annotation_txt.text = "Error opening "+playlist_url;
      playlist_listener.change = function(eventObject){
        annotation_txt.text = playlist_list.selectedItem.annotation;
        location_txt.text = playlist_list.selectedItem.location;
      function loadTrack(){
          //Radio Mode feature by nosferathoo, more info in: https://sourceforge.net/tracker/index.php?func=detail&aid=1341940&group_id=128363&atid=711 474
          if (radio_mode && track_index==playlist_size-1) {
              playlist_url=playlist_array[track_index].location;
              for (i=0;i<playlist_mc.track_count;++i) {
                  removeMovieClip(playlist_mc.tracks_mc["track_"+i+"_mc"]);
              playlist_mc.track_count=0;
              playlist_size=0;
              track_index=0;
              autoload=true;
              autoplay=true;
              loadPlaylist();
              return(0);
          start_btn_mc.start_btn._visible = false;
          track_display_mc.display_txt.text = playlist_array[track_index].label;
          }else{
          mysound.loadSound(playlist_array[track_index].location,true);
          play_mc.gotoAndStop(2)
          //info button
          if(playlist_array[track_index].info!=undefined){
              info_mc._visible = true;
              info_mc.info_btn.onPress = function(){
                  getURL(playlist_array[track_index].info,"_blank")
              info_mc.info_btn.onRollOver = function(){
                  track_display_mc.display_txt.text = info_button_text;
              info_mc.info_btn.onRollOut = function(){
          }else{
              info_mc._visible = false;
          resizeUI();
          _root.onEnterFrame=function(){
              //HACK doesnt need to set the volume at every enterframe
              mysound.setVolume(this.volume_level)
              var load_percent = (mysound.getBytesLoaded()/mysound.getBytesTotal())*100
              track_display_mc.loader_mc.load_bar_mc._xscale = load_percent;
              if(mysound.getBytesLoaded()==mysound.getBytesTotal()){
                  //_root.onEnterFrame = null;
      stop_btn.onRelease = stopTrack;
      play_mc.play_btn.onRelease = playTrack
      next_btn.onRelease = nextTrack
      prev_btn.onRelease = prevTrack
      mysound.onSoundComplete = nextTrack;
      volume_mc.volume_btn.onPress = volumeChange;
      volume_mc.volume_btn.onRelease = volume_mc.volume_btn.onReleaseOutside = function(){
          this._parent.onEnterFrame = null;
      function volumeChange(){
          this._parent.onEnterFrame = function(){
              var percent = (this._xmouse/this._width)*100
              if(percent>100)percent=100;
              if(percent<0)percent=0;
              this.volume_bar_mc._xscale = percent
              this._parent.volume_level = percent;
              mysound.setVolume(percent)
      function stopTrack() {
          mysound.stop();
          play_mc.gotoAndStop(1)
          mysound.stop();
          mysound.start();
          mysound.stop();
          _root.pause_position = 0;
      function playTrack() {
          if(play_mc._currentframe==1){ //play
              seekTrack(_root.pause_position)
          }else if(play_mc._currentframe==2){
              _root.pause_position = mysound.position;
              mysound.stop();
      function seekTrack(p_offset:Number){
          mysound.stop()
          mysound.start(int((p_offset)/1000),1)
      function nextTrack(){
          if(track_index<playlist_size-1){
              track_index ++;
              loadTrack();
          }else{
              if(repeat_playlist){
                  last_track_index = track_index;
                  track_index = 0;
                  loadTrack()
      function prevTrack(){
          if(track_index>0){
              track_index --;
              loadTrack();
      function scrollTitle(){
          track_display_mc.display_txt._x -= 5;
          if (track_display_mc.display_txt._x+track_display_mc.display_txt._width<0){
              track_display_mc.display_txt._x = track_display_mc.mask_mc._width;
      /*function resizeUI(){
          bg_mc._width = Stage.width;
          track_display_mc.loader_mc._width = Stage.width - track_display_mc._x - 3;
          track_display_mc.mask_mc._width = track_display_mc.loader_mc._width - 26;
          }else{
          if (info_mc._visible){
              info_mc._x = Stage.width - info_mc._width - 4;
          }else{
              info_mc._x = Stage.width - 4;
          volume_mc._x = info_mc._x - volume_mc._width - 2;
          start_btn_mc._xscale = Stage.width;
      function loadPlaylist(){
          track_display_mc.display_txt.text = LOADING_PLAYLIST_MSG;
          }else{
          //playlist
          if(playlist_url){
              playlist_xml.load(playlist_url)
          }else{
          //single track
              playlist_xml.parseXML(single_music_playlist)
              playlist_xml.onLoad(true);
      //first click - load playlist
      start_btn_mc.start_btn.onPress = function(){
          autoplay = true;
          loadPlaylist();
      //main
      //Stage.scaleMode = "noScale"
      //Stage.align = "LT";
      //this.onResize = resizeUI;
      Stage.addListener(this);
      if(!player_title) player_title = DEFAULT_WELCOME_MSG;
      track_display_mc.display_txt.autoSize = "left";
      track_display_mc.display_txt.text = player_title;
      }else{
      //start to play automatically if parameter autoplay is present
      if(autoplay){
          start_btn_mc.start_btn.onPress();
      } else if (autoload){
          loadPlaylist()
      //customized menu
      var my_cm:ContextMenu = new ContextMenu();
      my_cm.customItems.push(new ContextMenuItem("Stop", stopTrack));
      my_cm.customItems.push(new ContextMenuItem("Play!", playTrack));
      my_cm.customItems.push(new ContextMenuItem("Next", nextTrack));
      my_cm.customItems.push(new ContextMenuItem("Previous", prevTrack));
      my_cm.customItems.push(new ContextMenuItem("Download this song", function(){getURL(playlist_array[track_index].location)},true));
      my_cm.customItems.push(new ContextMenuItem("Add song to Webjay playlist", function(){getURL("http://webjay.org/poster?media="+escape(playlist_array[track_index].location))}));
      my_cm.customItems.push(new ContextMenuItem("About Hideout", function(){getURL("http://www.hideout.com.br")},true));
      //my_cm.customItems.push(new ContextMenuItem("Crossfade", function(){}));
      //my_cm.customItems.push(new ContextMenuItem("Mando Diao - Paralyzed", function(){}));
      my_cm.hideBuiltInItems();
      this.menu = my_cm;
      resizeUI();
