8 Replies Latest reply on Apr 12, 2009 7:06 PM by Wilson Edgar
    ResultEvent is always null
      Hi all
      I aplogise if this has been asked before but I've actually looked for an answer and couldn't find anytthing.
      <mx:Script>
      <![CDATA[
      import mx.messaging.channels.StreamingAMFChannel;
      import flash.net.sendToURL;
      import mx.controls.Alert;
      import mx.rpc.soap.SOAPFault;
      import mx.rpc.events.ResultEvent;
      import mx.rpc.events.FaultEvent;
      private function HandleFault(event:FaultEvent) : void
      Alert.show(event.fault.faultDetail, event.fault.faultString);
      private function HandleResult(event:ResultEvent) : void
      if(event != null){
      if(event.result != null){
      LblDisplayJava.text = event.result.toString();
      else{
      Alert.show("Event result is null", "Webservice result");
      else{
      private function InvokeWebService() : void
      JavaTestWebService.sayHelloWorldFrom.send(TxtName.text);
      private function InvokeHelloWorld() : void
      DotNetService.HelloWorld.send(TxtName.text);
      </mx:Script>
      <mx:WebService id="JavaTestWebService" wsdl="http://localhost:8080/services/HelloWorld?wsdl"
      showBusyCursor="true" useProxy="false"
      fault="HandleFault(event)" result="HandleResult(event)">
      <mx:operation name="sayHelloWorldFrom">
      <mx:request>
      <from>{TxtName.text}</from>
      </mx:request>
      </mx:operation>
      </mx:WebService>
      <mx:Panel x="0" layout="vertical">
      <mx:HBox>
      <mx:Label id="LblName" text="Type in your name:" />
      <mx:TextInput id="TxtName" width="300" />
      <mx:Button id="BtnRequestJava" click="InvokeWebService()" label="Salute Java"/>
      </mx:HBox>
      <mx:HBox>
      <mx:Label id="LblDisplayJava" text="This should be the result"/>
      </mx:HBox>
      </mx:Panel>
      This is invoking a simple java code
        public String sayHelloWorldFrom(String from) {
          //String result = "Hello, world " + from;
          System.out.println("Service invoked");
          return "Hello world Wilson Edgar";
      Everytime I run this I get event.result as null.
      The webservice is being invoked and everything seems to okay, except for the result. Now I've run the same code calling a .NET webservice and it works just fine. Unfortunately I have to develop my project in Java so any help would be much appreciated.
      Thanks in advance for you time
      Wilson Edgar
