1. Re: Capture window does not show video during playback
tclark513 Apr 11, 2009 7:53 PM (in response to Kent Jakusz)There is no preview for HDV capture.
2. Re: Capture window does not show video during playback
Eddie Lotter Apr 11, 2009 9:08 PM (in response to Kent Jakusz)You should be able to preview HDV before starting the capture on the Windows platform. Once capturing there is no monitoring of HDV.
Since your target is DVD I highly recommend you stick to 480i/60i, it will make your workflow seamless and you will get excellent quality to boot. Downconverting from HDV to the DVD spec is problematic for several technical reasons and is best avoided by the average videographer.
Cheers
Eddie -
3. Re: Capture window does not show video during playback
Eddie Lotter Apr 11, 2009 9:11 PM (in response to Eddie Lotter)P.S. I meant to point you to this site for capture troubleshooting tips.
Cheers
Eddie -
4. Re: Capture window does not show video during playback
Ann Bens Apr 12, 2009 3:22 AM (in response to Eddie Lotter)What's the point of having a hdv camera?
Shoot in HDV, edit in HDV and use Dan's method of converting to dvd.
If this is a problem downconvert in the camera.
Shooting in HDV will always give you the opportunity to get your material on BR.
5. DVD capture workflow
Kent Jakusz Apr 12, 2009 7:07 AM (in response to Ann Bens)Thanks for the great advise.
Ann can you please specify or link me to Dan's workflow for capture.
I do not understand what is meant by "down converting in the camera".
I have many hours of HDV that I need to capture and use in my library for future projects. Now I am working to final export for DVD but I suspect that it won't me long and I will be looking to export for Blue Ray.
Enjoy your holiday and thanks
Kent
6. Re: DVD capture workflow
Ann Bens Apr 12, 2009 11:29 AM (in response to Kent Jakusz)I also have a A1, i capture in HDV, edit in HDV and export to dvd using Dan's workflow which is exporting the timeline to HDV avi (i use Cineform codec). And with a avisynth script encoding it to m2v in HC Gui. (Curt can you make Dan's workflow in a FAQ.?)
If this methode does not work for you, you can capture in SD, which is downconverting in the camera. See the manual for the settings of the camera.
See also this thread: http://forums.adobe.com/thread/417714?tstart=30
7. Re: DVD capture workflow
Yes. We're workin on it.
9. Re: DVD capture workflow
Kent Jakusz Apr 12, 2009 6:07 PM (in response to Ann Bens)Ann
I am editing on a Mac can I assume that the workflow would be different?
Enjoy
Kent
10. Re: DVD capture workflow
Ann Bens Apr 13, 2009 2:30 AM (in response to Kent Jakusz)Ah, Mac.......
Most workflows described here are for PC.
11. Re: Capture window does not show video during playback
Kent Jakusz Apr 16, 2009 6:17 AM (in response to Eddie Lotter)Thanks for the tips and input. I will certainly give them a try. I sure appreciate your time. I am just getting started
and struggling but enjoying it.
Kent
12. Re: Capture window does not show video during playback
Eddie Lotter Apr 16, 2009 6:47 AM (in response to Kent Jakusz)I am just getting started
You will find links to many free tutorials in the PremiereProPedia that will quickly show you how things are done in Premiere Pro.
Cheers
Eddie
