3 Replies Latest reply on Apr 14, 2009 6:59 PM by savyasachi
    How to hide itemRenderers in the Grouped rows of an AdvancedDataGrid?
    savyasachi
      I am using an AdvancedDataGrid and showing a comboBox as the itemRenderer and also the editRenderer. However I am seeing the combobox in the grouped rows also. Below is the code I am using and also attached the screenshot of the app. Please help.
      TestAdvGridGrpRen.mxml
      <?xml version="1.0"?>
      <!-- dpcontrols/adg/SummaryGroupADGCustomSummary.mxml -->
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
          <mx:Script>
              <![CDATA[
                  import mx.collections.ArrayCollection;
                  import mx.controls.advancedDataGridClasses.AdvancedDataGridColumn;
                  import mx.collections.IViewCursor;
                  import mx.collections.SummaryObject;
      [Bindable]
      private var dpFlat:ArrayCollection = new ArrayCollection([
        {Region:"Southwest", Territory:"Arizona",
            Territory_Rep:"Barbara Jennings", Actual:38865, Estimate:40000},
            Territory_Rep:"Dana Binn", Actual:29885, Estimate:30000},
        {Region:"Southwest", Territory:"Central California",
            Territory_Rep:"Joe Smith", Actual:29134, Estimate:30000},
        {Region:"Southwest", Territory:"Nevada",
            Territory_Rep:"Bethany Pittman", Actual:52888, Estimate:45000},
        {Region:"Southwest", Territory:"Northern California",
            Territory_Rep:"Lauren Ipsum", Actual:38805, Estimate:40000},
            Territory_Rep:"T.R. Smith", Actual:55498, Estimate:40000},
        {Region:"Southwest", Territory:"Southern California",
            Territory_Rep:"Alice Treu", Actual:44985, Estimate:45000},
            Territory_Rep:"Jane Grove", Actual:44913, Estimate:45000}
                  // Callback function to create
                  // the SummaryObject used to hold the summary data.
                  private function summObjFunc():SummaryObject {
                      // Define the object containing the summary data.
                      var obj:SummaryObject = new SummaryObject();
                      // Add a field containing a value for the Territory_Rep column.
                      obj.Territory_Rep = "Alternating Reps";
                      return obj;
                  // Callback function to summarizes
                  // every other row of the Actual sales revenue for the territory.
                  private function summFunc(cursor:IViewCursor, dataField:String,
                      operation:String):Number {
                      var oddCount:Number = 0;
                      var count:int = 1;
                      while (!cursor.afterLast)
                          if (count % 2 != 0)
                              oddCount += cursor.current["Actual"];
                          cursor.moveNext();
                          count++;
                      return oddCount;
          </mx:Script>
          <mx:AdvancedDataGrid id="myADG"
              width="100%" height="100%"
              initialize="gc.refresh();">
              <mx:dataProvider>
                  <mx:GroupingCollection id="gc" source="{dpFlat}">
                      <mx:Grouping>
                         <mx:GroupingField name="Region"/>
                         <mx:GroupingField name="Territory">
                            <mx:summaries>
                               <mx:SummaryRow summaryObjectFunction="summObjFunc"
                                  summaryPlacement="first">
                                  <mx:fields>
                                     <mx:SummaryField dataField="Actual" summaryFunction="summFunc"/>
                                  </mx:fields>
                               </mx:SummaryRow>
                            </mx:summaries>
                         </mx:GroupingField>
                      </mx:Grouping>
                  </mx:GroupingCollection>
              </mx:dataProvider>
              <mx:columns>
                  <mx:AdvancedDataGridColumn dataField="Region"/>
                  <mx:AdvancedDataGridColumn dataField="Territory_Rep"
                      headerText="Territory Rep"/>
                  <mx:AdvancedDataGridColumn headerText="Actual" dataField="Actual"
                  rendererIsEditor="true"
                  itemRenderer="TestStatusTypeEditor"
                  editorDataField="type"/>
                  <mx:AdvancedDataGridColumn dataField="Estimate"/>
              </mx:columns>
         </mx:AdvancedDataGrid>
      </mx:Application>
      TestStatusTypeEditor.mxml
      <mx:ComboBox xmlns:mx="http://www.adobe.com/2006/mxml"
      creationComplete="OnInit()" >
      <!-- This is the content of the ComboBox.
      <mx:dataProvider>
      <mx:Object label="Cog" />
      <mx:Object label="Sproket" />
      </mx:dataProvider>
      <mx:Script>
      <![CDATA[
              [Bindable]
              public var cards:ArrayCollection = new ArrayCollection(
                  [ {label:"38865", data:1},
                    {label:"29885", data:2},
                    {label:"29134", data:3},
                    {label:"52888", data:4},
                    {label:"38805", data:5},
                    {label:"55498", data:6},
                    {label:"44985", data:7},
                    {label:"44913", data:8}]);
      private function OnInit():void
      dataProvider = cards;
      * This override of set data compares the data.label against the label property
      * of each item in the dataProvider (above). This code is written a bit more
      * generically than necessary, but it would allow you to have a long list
      * in the dataProvider and not have to change this code.
      override public function set data(value:Object):void
      super.data = value;
      var list:ArrayCollection = dataProvider as ArrayCollection;
      for(var i:int=0; i < list.length; i++)
      if( String(value.statusName) == list[i].label ) {
      selectedIndex = i;
      * This getter is the one identified as the editorDataField in the list for
      * the itemEditor.
      public function get type() : String
      if( selectedItem ) {
      return selectedItem.label;
      else {
      return null;
      </mx:Script>
      </mx:ComboBox>
        • 1. Re: How to hide itemRenderers in the Grouped rows of an AdvancedDataGrid?
          _Natasha_ Level 4
          You need to change function
          override public function set data(value:Object):void {}
          to check the type of value.
          If it's a grouped data you need to set this.visible = false and this.visible = true and your code otherwise.
          • 2. Re: How to hide itemRenderers in the Grouped rows of an AdvancedDataGrid?
            savyasachi Level 1
            Thanks for your solution. Looks promising.
            How do I verify if the value is Grouped Item or not? Appreciate if you can some pointers - sample code or property name...etc.
            Thanks.
            • 3. Re: How to hide itemRenderers in the Grouped rows of an AdvancedDataGrid?
              savyasachi Level 1
              Solved this issue by using mx:rendererProviders element for my AdvancedGrid. Using the depth parameter gives me the ability to hide the itemRenderer for the Grouped rows.
                      <mx:dataProvider>
                              <mx:Grouping>
                                    <mx:summaries>
                                          <mx:fields>
                                          </mx:fields>
                                       </mx:SummaryRow>
                                    </mx:summaries>
                                 </mx:GroupingField>
                              </mx:Grouping>
                      </mx:dataProvider>
                      <mx:columns>
                      </mx:columns>
              <mx:rendererProviders>
                  <mx:AdvancedDataGridRendererProvider
                      columnIndex="2"
                      columnSpan="1"
                      depth="3"
                      renderer="TestStatusTypeEditor"/>
              </mx:rendererProviders>
