2 Replies Latest reply on Apr 12, 2009 3:51 PM by kglad
    as3-cs4 package.as subclasses MovieClip, fla generates error 5000 anyway
      Hi, I am working with a trial version of Flash CS4 on a leopard intel mac.
      Starting with a clean os install, and a clean cs4 install I do the following
      start Adobe Flash CS4: Trial Version
      Select "I would like to continue to use this product on a trial basis" and continue...
      select create new Flash File (action script 3.0)
      open actions window
      type the following..
      trace("hello world");
      save file test_report.fla
      test file
      output ok.
      close swf window
      file > new > action script file
      type in the following code
      package {
          public class test_report{
              public function test_report(){
                  trace("Hello world");
      select the test_report.fla tab
      fill in the "Class:" textbox of the property window with the string "test_report"
      click the pencil icon to test that pathing is ok, the UI opens test_report.as so it must be ok.
      test the movie
      2 errors
      1180: Call to a possibley undefined method addFrameScript
      5000: the class "test_report" must subclass 'flash.display.MovieClip' yada yada
      so add the offending line to the as file so that it looks like this..
      package {
              import flash.display.MovieClip;
      save and test movie, same two errors
      AS IF I HAD NOT MADE THE ENTRY!
      NOTHING I CAN DO WILL MAKE THE ERROR GO AWAY
      obviously I am doing something wrong, please help!
      I only have 15 days left on the trial and I would really like to know I can get this to work on leopard!
      thanks
      rob
      Hardware Overview:
        Model Name:    iMac
        Model Identifier:    iMac7,1
        Processor Name:    Intel Core 2 Duo
        Processor Speed:    2.4 GHz
        Number Of Processors:    1
        Total Number Of Cores:    2
        L2 Cache:    4 MB
        Memory:    1 GB
        Bus Speed:    800 MHz
        Boot ROM Version:    IM71.007A.B03
        SMC Version:    1.20f4
        Serial Number:    W880759YX86
        System Version:    Mac OS X Server 10.5.6 (9G71)
        Kernel Version:    Darwin 9.6.0
        Boot Volume:    workSystem
        Boot Mode:    Normal
        Computer Name:    kbox
        User Name:    rob foree (robforee)
        Time since boot:    1:02
