5 Replies Latest reply on Sep 11, 2008 10:04 AM by Newsgroup_User
    PVII Pop Menu Magic Help
    destind4film Level 1
      Looking for help from Al Sparber on this if possible.
      I have the Pop Menu Magic on a site and am trying to make some modifications to it but am getting strange results. In IE I noticed a strange problem where the submenu seems to jump out far away from the rest of the menu.
      I also am trying to make some minor change like having all submenus left justified instead of centered and make the columns smaller.
      Here is a link to see what I am working with:
      http://www.dvdflashbacks.com/williamsburghealth/index.php
      Thanks in advance.
        • 1. Re: PVII Pop Menu Magic Help
          Level 7
          suggest posting directly to the projectseven.com support forums.
          Alan
          Adobe Community Expert, dreamweaver
          http://www.adobe.com/communities/experts/
          • 2. Re: PVII Pop Menu Magic Help
            Level 7
            "destind4film" <webforumsuser@macromedia.com> wrote in message
            news:gab81e$ium$1@forums.macromedia.com...
            > modifications
            > where
            you should probably go to their support forums at forums.projectseven.com -
            great help can be found there.
            • 3. Re: PVII Pop Menu Magic Help
              Level 7
              As Alan and Hunter say, your best bet is to got to the Project Seven
              forums...
              However, and this is without looking at your code, i suspect:
              1/ You have given a 'center' in the parent - the main links are centred. You
              need to correct that for the sub menus.
              2/ You have probably narrowed the sub menus, without compensating for that
              in the offset of the sub-sub menus.
              But as A & H say... the PVII forums are your best bet.
              Cheers...
              • 4. Re: PVII Pop Menu Magic Help
                Hey guys,
                Thanks for the suggestions. Sorry for posting this in the Adobe Forum, but I had two reasons for doing so:
                1) I can not access the newgroup support system that PVII guys use from my work, we use Lotus here and IE is pretty much locked down. It is a miracle I can even come to the Adobe forums.
                2) I thought Al pops in here from time to time so I figured it was worth a shot.
                Thanks again.
                • 5. Re: PVII Pop Menu Magic Help
                  Level 7
                  > modifications
                  > where
                  This is causing the problem:
                  <tr align="center">
                  IE has a very odd way of handling the align attribute or the CSS text-align
                  property.
                  Remove the TR attribute.
                  Then, if you want to center the submenu items, use this rule:
                  #p7PMnav ul a {text-align: center;}
                  In the future, if you need us when you are at work, pop us a mail or call
                  us. It's probably quicker :-)
                  Al Sparber - PVII
                  http://www.projectseven.com
                  Fully Automated Menu Systems | Galleries | Widgets
                  http://www.projectseven.com/go/Elevators
