1 Reply Latest reply on Apr 13, 2009 11:54 AM by agroom
    Blurry Video Exports
      I am working on a new project using the CS4 Master Collection and experiencing some issues using Premier Pro CS4.
      I've created a new project in Adobe After Effects CS4 and exported a quicktime movie with high quality "animation" settings
      applied to it.  The animation exports perfectly and is as crisp and clear as it gets.
      After importing this video into Premiere, applying some audio and and a title, then exporting, I get blurry video.
      I have tried almost 30 different settings to export the video even using the animation setting in Premier. ( which ends up looking like a compressed .gif file! )
      No matter what I try, it's always blurry and compressed looking.  So far the best setting for quality is using the "Apple Intermediate Codec".
      However, it's still not comparable to the After Effects Settings.
      Here are my settings for After Effects:
      Quality: Best
      Resolution: Full
      Frame rate: 29.97
      Format: Quicktime Movie
      Pixel Aspet Ratio: D1 / DV NTSC (0.91)
      Output Info: Animation
      Channels: RGB
      Depth: Millions of Colors
      And my Premiere Project Settings:
      Editing Mode: Quicktime DV NTSC
      Timebase: 29.97
      Frame Size: 720x480
      Pixel Aspect Ratio: D1 / DV NTSC (0.9091)
      Fields: Lower Field First
      Display Format:  30fps Drop -Frame Time Code
      Model Name:    Mac Pro
        Model Identifier:    MacPro3,1
        Processor Name:    Quad-Core Intel Xeon
        Processor Speed:    2.8 GHz
        Number Of Processors:    2
        Total Number Of Cores:    8
        L2 Cache (per processor):    12 MB
        Memory:    4 GB
        Bus Speed:    1.6 GHz
        Chipset Model:    ATI Radeon HD 2600
        Type:    Display
        Bus:    PCIe
        Slot:    Slot-1
        PCIe Lane Width:    x16
        VRAM (Total):    256 MB
      2 Hannspree 1680x1050 monitors, both using vga to dvi adaptors into the computer.
      I am new to Premier Pro CS4, I have been using FCP for quite awhile.  If any one can lend a hand I would truly appreciate it, I am totally puzzled!
      If you need more settings please let me know.
      Thank you!!!!
