3 Replies Latest reply on Apr 30, 2009 10:30 PM by newchickinCF
    CFC Issue when invoking a method
    apocalipsis19 Level 1
      Hello Community:
      I am getting the following error message when invoking my CFC:
      "If the component name is specified as a type of this argument, its possible that a definition file for the component cannot be found or is not accessible."
      This is the code where I call the method:
      <cfinvoke component="cfc.cartSelection" method="#meth#">
                      <cfinvokeargument name="inum" value="#ihdnum#">
                      <cfinvokeargument name="qty" value="#qty#">
                  </cfinvoke>
      Any thoughts are deeply appreciated!
      Ysais.
        • 1. Re: CFC Issue when invoking a method
          Dan Bracuk Level 5
          The two things that jump out at me are the component and method attributes of your cfinvoke tag.  Is the name of your cfc file really cfc.CartSelection.cfc?  Plus, using a variable to for the method you want to run is something you don't see very often.
          • 2. Re: CFC Issue when invoking a method
            insuractive Level 3
            Check the following:
            1) That the following path will reach your CFC: "/cfc/cartSelection.cfc" - if not, you may need to set up a CF mapping to point /cfc to the correct directory
            2) Have you tried hardcoding in the value of the method?  Does that return a valid result, or are you still getting the same error?
            • 3. Re: CFC Issue when invoking a method
              newchickinCF Level 1
              Hi, You specified this:
              cfc.cartSelection
              check to make sure that you have a cfc folder and cartSelection.cfc as the CFC inside the CFC Folder.
              I would suggest you 1 way. if you are using application.cfc or application.cfm:
              try as:
              <cfset request.cfcPath = cfc>
              if you cfc is in admin path and application.cfm file is outside the admin root
              you can fetch it as:
              <cfset request.cfcPath =admin.cfc>
              Try it and let me know how it goes.
              Also your method name is dynamic, make sure the method name you are calling exist or not.
