Hi everyone!
I noticed that a .TMP file saves automatically with my Captivate projects, such as this one: Ado4F2.tmp. Out of curiosity, what is the function of this file and is it crucial that it is saved in the same folder as the original CP file? The reason I ask the latter is because it doesn't seem as though I'm able to move it when I move other CP files.
Thanks, O Wise Captivate Gurus!
Krista
Hello Krista,
Captivate .tmp files are the name implies are temporary files. Typically temp files are created by applications to store some form of temporary data, in a permanent form than RAM, on your hard disk. TMP files are commonly produced either when a program can't allocate enough memory for its tasks, or as part of inter-process communication.
Some Captivate users have had success in restoring their Captivate projects from the .tmp file. In Adobe Captivate 4 by default you will also notice that you have a .bak file. This is a backup of your Captivate project which you can use if for some reason your Captivate project file becomes corrupted.
HTH
Best - Mark
