4 Replies Latest reply on Apr 26, 2009 6:14 AM by HowardTreisman
    Invalid XML character error when indexing XML node
    JoshDBoyle
      All
      I have an XML document of the following form:
      <RootNode>
           <ChildNode>
                <ChildA/>
                <ChildB/>
                <ChildC/>
           </ChildNode>
           <ChildNode>
                <ChildA/>
                <ChildB/>
                <ChildC/>
           </ChildNode>
      </RootNode>
      What I need is a means to insert a new node underneath one of the <ChildNode> elements.  However, this requires indexing to specify which <ChildNode> I'd like to add to.  So, using a SetValue, I have the following left-hand side of an expression:
      /process_data/xmlVar/RootNode/ChildNode[2]/NewNode
      and on the right-hand side of the expression:
      'test'
      However, the above throws an XML parsing error stating that an "invalid XML character was specified".  If I simply remove the indexing from the left-hand side to yield:
      /process_data/xmlVar/RootNode/ChildNode/NewNode
      the SetValue properly adds the node <NewNode> but it does so under the first <ChildNode> - which I understand.
      So my question is simply:  "How does one index their XML expression properly when trying to dynamically build XML?"  I have tried putting both single quotes and double quotes around the index but to no avail.
      Thanks in advance.
        • 1. Re: Invalid XML character error when indexing XML node
          Steve L Walker Level 5
          XPath is not your friend when it comes to adding nodes. XSLT is not necessarily your friend either but it works.
          I built the attached process to insert a third 'ChildNode'
               <ChildNode>
                    <ChildA>A3</ChildA><ChildB>B3</ChildB><ChildC>C3</ChildC>
               </ChildNode>
          into
          <RootNode>
               <ChildNode>
                    <ChildA>A1</ChildA><ChildB>B1</ChildB><ChildC>C1</ChildC>
               </ChildNode>
               <ChildNode>
                    <ChildA>A2</ChildA><ChildB>B2</ChildB><ChildC>C2</ChildC>
               </ChildNode>
          </RootNode>
          to produce
          <RootNode>
                <ChildNode>
                </ChildNode>
                <ChildNode>
                </ChildNode>
               <ChildNode>
               </ChildNode>
          </RootNode
          The XSLT goes like this
          <xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform" version="1.0">
            <xsl:param name="childA">ChildA</xsl:param>
            <xsl:param name="childA_text">{$ /process_data/@childNodeA $}</xsl:param>
            <xsl:param name="childB">ChildB</xsl:param>
            <xsl:param name="childB_text">{$ /process_data/@childNodeB $}</xsl:param>
            <xsl:param name="childC">ChildC</xsl:param>
            <xsl:param name="childC_text">{$ /process_data/@childNodeC $}</xsl:param>
            <xsl:output method="xml" encoding="utf-8"/>
            <xsl:template match="@*|node()">
               <xsl:copy>
                 <xsl:apply-templates select="@*|node()"/>
               </xsl:copy>
            </xsl:template>
            <xsl:template match="RootNode">
               <xsl:copy>
                   <xsl:apply-templates/>
                    <xsl:if test="position()=last()">
                       <ChildNode>
                  <xsl:element name="{$childA}"><xsl:value-of select="$childA_text"/></xsl:element>
                  <xsl:element name="{$childB}"><xsl:value-of select="$childB_text"/></xsl:element>
                  <xsl:element name="{$childC}"><xsl:value-of select="$childC_text"/></xsl:element>
                   </ChildNode>
                    </xsl:if>
               </xsl:copy>
            </xsl:template>
          </xsl:stylesheet>
          Steve
          • 2. Re: Invalid XML character error when indexing XML node
            robschild@gmail.com
            Hi Steve,
            Never heard back from you.  If you can't help, please let me know.
            Besy,
            Rob
            • 3. Re: Invalid XML character error when indexing XML node
              robschild@gmail.com Level 1
              Sorry,
              Best,
              Rob
              Sent via BlackBerry from T-Mobile
