3 Replies Latest reply on Apr 18, 2009 6:52 PM by the_wine_snob
    Superimposing Faces in CS3
      I want to superimpose a picture of my friends face over the face of another who is imitating the first one. Its not alot of footage, just a few seconds and then it loops back in reverse. I have the picture and i tried doing it with just making titles but it seems really inefficient. I then found motion keyframming and i know that i have to use position in motion keframming but i cant seem to figure it out myself.
      Has anyone done this or knows where i could look to find help? Thanks!
        • 1. Re: Superimposing Faces in CS3
          Eddie Lotter Level 4
          Welcome to the forums.
          Have a look at this thread for ideas.
          You will also find links to many free tutorials in the PremiereProPedia that will quickly show you how things are done in Premiere Pro.
          Cheers
          Eddie
          • 2. Re: Superimposing Faces in CS3
            Level 1
            thanks eddie ill get started on this!
            • 3. Re: Superimposing Faces in CS3
              the_wine_snob Level 9
              I'd look at Track Matte Keying Effect (in Eddie's tutorials). Depending on how linear the head "movement" is, you can probably do a couple of Export>Still from your new "head" footage, and then bring these into Photoshop. There, create a mask for the head and use that mask as your Track Matte. You can use Motion>Position (and Scale) on it, along with these Effects on your new "head" footage, to mask out eveything but the head for your new composited footage. The less linear your head movement is, the more changes in the Track Matte you are likely to need. AfterEffects would make this a bit easier, but unless you have a lot of sizing changes and movement, you can probably do a nice job in PrPro. Tip, you might want to add a touch of Gaussian Blur to the edges of the Track Matte masks, just to soften the transition to the underlying footage. Tip 2: if you get the size and movement set via Keyframes in either the mask, or the new "head" footage, you can Rt-click and Copy, then Rt-click on the other Clip and choose Paste Attributes. I'd make sure that the Duration of both is the same, so the Keyframing copies over perfectly. Establish your Durations first, then work on the Keyframing.
