2 Replies Latest reply on Apr 16, 2009 3:09 AM by camLodge
    escape isn't fully working for url encoding
      Hello all,
      I was trying to use the escape command so that I can url encode a String:
      var encodedValue : String =    escape(blah.hashCodeValue);
      But the encodedValue generated wasn't what I'd expect.
      1. If string to be url encoded includes a plus sign
      if you use escape on b55Cj0bDALCTYeO+evckxmMHPWQ= the encodedValue is b55Cj0bDALCTYeO+evckxmMHPWQ%3D
      As you can the plus sign is still present.
      I tried an online tool  (http://www.opinionatedgeek.com/DotNet/Tools/UrlEncode/Encode.aspx) to see what the string should look like.
      So using the online tool, if you url encode b55Cj0bDALCTYeO+evckxmMHPWQ=   you get b55Cj0bDALCTYeO%2bevckxmMHPWQ%3d
      You can see here that the plus sign is removed and replaced by %2b
      2. If string to be url encoded includes a forward slash sign
      if you use escape on A6d/rkKds/BCijUDdWwF0AJPTas= you get A6d/rkKds/BCijUDdWwF0AJPTas%3D
      As you can see the forward slashes are still present
      I would like it to be encoded as "A6d%2frkKds%2fBCijUDdWwF0AJPTas%3d"  (/ is replaced with %2f)
      Can anyone suggest anything please ?
      Best Regards,
      Trish.
