3 Replies Latest reply on Apr 15, 2009 7:05 PM by RossRitchey
    Drag and Drop then Recognize
    goalpost95
      Alright I'm wondering how I can get the landing area to recognize different symbols and then go to a certain frame depending on what symbol is placed in the landing area
      here is my code now
      onMouseMove = function(){
      updateAfterEvent();
      // Design And Culture MC
      desCult.onPress = function(){
      startDrag(this,true)
      desCult.onRelease = function(){
      this.stopDrag();
      checkTarget(this);
      desCult.onReleaseOutside = function(){
      this.stopDrag();
      checkTarget(this);
      //Drawing Fire MC
      drawFire.onPress = function(){
      drawFire.onRelease = function(){
      this.stopDrag();
      checkTarget(this);
      drawFire.onReleaseOutside = function(){
      this.stopDrag();
      checkTarget(this);
      //Good Apple MC
      goodApple.onPress = function(){
      goodApple.onRelease = function(){
      this.stopDrag();
      checkTarget(this);
      goodApple.onReleaseOutside = function(){
      this.stopDrag();
      checkTarget(this);
      // Bad Apple MC
      badApple.onPress = function(){
      badApple.onRelease = function(){
      this.stopDrag();
      checkTarget(this);
      badApple.onReleaseOutside = function(){
      this.stopDrag();
      checkTarget(this);
      // Captain America Skateboard MC
      capSkate.onPress = function(){
      capSkate.onRelease = function(){
      this.stopDrag();
      checkTarget(this);
      capSkate.onReleaseOutside = function(){
      this.stopDrag();
      checkTarget(this);
      // TShirt MC
      tShirt.onPress = function(){
      tShirt.onRelease = function(){
      this.stopDrag();
      checkTarget(this);
      tShirt.onReleaseOutside = function(){
      this.stopDrag();
      checkTarget(this);
      function checkTarget(drag){
      if (drag.hitTest(greyCircle)) {
      drag+ gotoAndStop (54);
      drag.swapDepths(1000000);
      drag.removeMovieClip();
      } else {
      gotoAndStop (53);
        • 1. Re: Drag and Drop then Recognize
          RossRitchey Level 4
          You are already passing the object into the checkTarget function when you call it.
          So, the easiest method would be to check the instance name of the clip if the hitTest is true:
          var dragName = drag._name;
          switch(dragName){
               case "desCult":
               //go to frame that desCult references
               break;
               case "drawFire":
               //go to frame that drawFire references
               break;
          (Also, a more reliable method for doing that swapDepth)
          drag.swapDepth(this.getNextHighestDepth()-1);
          This way you always swap with the highest object, and never run into problems where you have more objects than the number you put in.  I know, it is highly unlikely that you will ever have more than 1 million objects, and the Flash would probably crash at that point, but it is a guarantee.
          • 2. Re: Drag and Drop then Recognize
            goalpost95 Level 1
            so then the code would look like this?
            updateAfterEvent();
            this.stopDrag();
            checkTarget(this);
            this.stopDrag();
            checkTarget(this);
            //Drawing Fire MC
            this.stopDrag();
            checkTarget(this);
            this.stopDrag();
            checkTarget(this);
            //Good Apple MC
            this.stopDrag();
            checkTarget(this);
            this.stopDrag();
            checkTarget(this);
            // Bad Apple MC
            this.stopDrag();
            checkTarget(this);
            this.stopDrag();
            checkTarget(this);
            this.stopDrag();
            checkTarget(this);
            this.stopDrag();
            checkTarget(this);
            // TShirt MC
            this.stopDrag();
            checkTarget(this);
            this.stopDrag();
            checkTarget(this);
            switch(dragName){
                case "desCult":   // put in "gotoAndPlay (55 );"  here?
                 break;
                 case "drawFire":
                 break;
            } else {
            gotoAndStop (53);
            • 3. Re: Drag and Drop then Recognize
              RossRitchey Level 4
              Yes, and you would replace the "//go to frame that desCult/drawFire references" with the script to do what you want based off of the object dropped.
