6 Replies Latest reply on Jul 14, 2009 1:02 AM by Nico Weyens
    Filename problem while invoking process (com.adobe.idp.dsc.RequiredParameterException)
    Nico Weyens
      Hello,
      We have a working process that's being triggered by an email endpoint.
      For every PDF attachment that is being sent to a specific address, 1 instance of the process is being started.
      This works fine.
      However, when the filename of the PDF attachment contains "special" characters like é, è, ù, á, ü, ... the process fails.
      The server.log contains several errors saying that a required input parameter (the pdf) is missing...
      I tested with "éa.pdf". In the server.log I see that "éa.pdf" has been changed to "éa.pdf".
      All help is very welcome...
      Here is the server.log :
      ERROR [com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker] An exception was thrown with name com.adobe.idp.dsc.RequiredParameterException message:Parameter: inPdfDoc is required. while invoking service FormDataIntegration and operation exportData and no fault routes were found to be configured.
      ERROR [com.adobe.idp.jobmanager.ejb.JobManagerBean] JobManagerBean:onMessage():Exception:ALC-DSC-002-000: com.adobe.idp.dsc.RequiredParameterException: Parameter: inPdfDoc is required.
      ERROR [STDERR] ALC-DSC-002-000: com.adobe.idp.dsc.RequiredParameterException: Parameter: inPdfDoc is required.
      ERROR [STDERR]  at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:117)
      ERROR [STDERR]  at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
      ERROR [STDERR]  at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
      ERROR [STDERR]  at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTr ansactionCMTAdapterBean.java:342)
      ERROR [STDERR]  at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doRequired(Ej bTransactionCMTAdapterBean.java:259)
      ERROR [STDERR]  at sun.reflect.GeneratedMethodAccessor264.invoke(Unknown Source)
      ERROR [STDERR]  at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
      ERROR [STDERR]  at java.lang.reflect.Method.invoke(Method.java:585)
      ERROR [STDERR]  at org.jboss.invocation.Invocation.performCall(Invocation.java:359)
      ERROR [STDERR]  at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionConta iner.java:237)
      ERROR [STDERR]  at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionI nterceptor.java:158)
      ERROR [STDERR]  at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstance Interceptor.java:169)
      ERROR [STDERR]  at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:63)
      ERROR [STDERR]  at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:121)
      ERROR [STDERR]  at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:350)
      ERROR [STDERR]  at org.jboss.ejb.plugins.TxInterceptorCMT.invoke(TxInterceptorCMT.java:181)
      ERROR [STDERR]  at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:168)
      ERROR [STDERR]  at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
      ERROR [STDERR]  at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor. java:138)
      ERROR [STDERR]  at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:648)
      ERROR [STDERR]  at org.jboss.ejb.Container.invoke(Container.java:960)
      ERROR [STDERR]  at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:430)
      ERROR [STDERR]  at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:103)
      ERROR [STDERR]  at $Proxy170.doRequired(Unknown Source)
      ERROR [STDERR]  at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:129)
      ERROR [STDERR]  at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInt erceptor.java:72)
      ERROR [STDERR]  at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStra tegyInterceptor.java:55)
      ERROR [STDERR]  at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercep tor.java:37)
      ERROR [STDERR]  at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:132)
      ERROR [STDERR]  at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
      ERROR [STDERR]  at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:115)
      ERROR [STDERR]  at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:118)
      ERROR [STDERR]  at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessage Receiver.java:91)
      ERROR [STDERR]  at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:21 5)
      ERROR [STDERR]  at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:57)
      ERROR [STDERR]  at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
      ERROR [STDERR]  at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:724)
      ERROR [STDERR]  at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.transientInvoke(WorkflowDSCInvoker. java:346)
      ERROR [STDERR]  at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(WorkflowDSCInvoker.java:157)
      ERROR [STDERR]  at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:140)
      ERROR [STDERR]  at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doRequiresNew (EjbTransactionCMTAdapterBean.java:284)
      ERROR [STDERR]  at sun.reflect.GeneratedMethodAccessor261.invoke(Unknown Source)
      ERROR [STDERR]  at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:404)
      ERROR [STDERR]  at $Proxy170.doRequiresNew(Unknown Source)
      ERROR [STDERR]  at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:143)
      ERROR [STDERR]  at com.adobe.idp.jobmanager.ejb.JobManagerBean.doOnMessage(JobManagerBean.java:1104)
      ERROR [STDERR]  at com.adobe.idp.jobmanager.ejb.JobManagerBean.onMessage(JobManagerBean.java:952)
      ERROR [STDERR]  at sun.reflect.GeneratedMethodAccessor915.invoke(Unknown Source)
      ERROR [STDERR]  at org.jboss.ejb.MessageDrivenContainer$ContainerInterceptor.invoke(MessageDrivenContainer.j ava:495)
      ERROR [STDERR]  at org.jboss.ejb.plugins.AbstractTxInterceptorBMT.invokeNext(AbstractTxInterceptorBMT.java:1 73)
      ERROR [STDERR]  at org.jboss.ejb.plugins.MessageDrivenTxInterceptorBMT.invoke(MessageDrivenTxInterceptorBMT. java:47)
      ERROR [STDERR]  at org.jboss.ejb.plugins.MessageDrivenInstanceInterceptor.invoke(MessageDrivenInstanceInterc eptor.java:116)
      ERROR [STDERR]  at org.jboss.ejb.plugins.RunAsSecurityInterceptor.invoke(RunAsSecurityInterceptor.java:109)
      ERROR [STDERR]  at org.jboss.ejb.MessageDrivenContainer.internalInvoke(MessageDrivenContainer.java:402)
      ERROR [STDERR]  at org.jboss.ejb.plugins.jms.JMSContainerInvoker.invoke(JMSContainerInvoker.java:987)
      ERROR [STDERR]  at org.jboss.ejb.plugins.jms.JMSContainerInvoker$MessageListenerImpl.onMessage(JMSContainerI nvoker.java:1287)
      ERROR [STDERR]  at org.jboss.jms.asf.StdServerSession.onMessage(StdServerSession.java:266)
      ERROR [STDERR]  at org.jboss.mq.SpyMessageConsumer.sessionConsumerProcessMessage(SpyMessageConsumer.java:891 )
      ERROR [STDERR]  at org.jboss.mq.SpyMessageConsumer.addMessage(SpyMessageConsumer.java:170)
      ERROR [STDERR]  at org.jboss.mq.SpySession.run(SpySession.java:323)
      ERROR [STDERR]  at org.jboss.jms.asf.StdServerSession.run(StdServerSession.java:194)
      ERROR [STDERR]  at EDU.oswego.cs.dl.util.concurrent.PooledExecutor$Worker.run(PooledExecutor.java:748)
      ERROR [STDERR]  at java.lang.Thread.run(Thread.java:595)
      ERROR [com.adobe.idp.dsc.provider.service.email.impl.EmailWriterImpl] EmailWriterImpl error : Could not connect to SMTP host: localhost, port: 25
      ERROR [STDERR] javax.mail.MessagingException: Could not connect to SMTP host: localhost, port: 25;
        nested exception is:
      java.net.ConnectException: Connection refused: connect
      ERROR [STDERR]  at com.sun.mail.smtp.SMTPTransport.openServer(SMTPTransport.java:1282)
      ERROR [STDERR]  at com.sun.mail.smtp.SMTPTransport.protocolConnect(SMTPTransport.java:370)
      ERROR [STDERR]  at javax.mail.Service.connect(Service.java:275)
      ERROR [STDERR]  at javax.mail.Service.connect(Service.java:156)
      ERROR [STDERR]  at com.adobe.idp.dsc.provider.service.email.impl.EmailWriterImpl.send(EmailWriterImpl.java:2 54)
      ERROR [STDERR]  at com.adobe.idp.dsc.provider.service.email.impl.write.EmailResultHandlerImpl.handleFailure( EmailResultHandlerImpl.java:440)
      ERROR [STDERR]  at com.adobe.idp.dsc.provider.service.email.impl.write.EmailResultHandlerImpl.handleFailure( EmailResultHandlerImpl.java:375)
      ERROR [STDERR]  at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      ERROR [STDERR]  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
      ERROR [STDERR]  at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:118)
      ERROR [STDERR]  at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doSupports(Ej bTransactionCMTAdapterBean.java:212)
      ERROR [STDERR]  at sun.reflect.GeneratedMethodAccessor348.invoke(Unknown Source)
      ERROR [STDERR]  at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:378)
      ERROR [STDERR]  at $Proxy170.doSupports(Unknown Source)
      ERROR [STDERR]  at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:104)
      ERROR [STDERR]  at com.adobe.idp.jobmanager.ejb.JobManagerBean.processFaultCallBackInfo(JobManagerBean.java: 1383)
      ERROR [STDERR]  at com.adobe.idp.jobmanager.ejb.JobManagerBean.doOnMessage(JobManagerBean.java:1240)
      ERROR [STDERR] Caused by: java.net.ConnectException: Connection refused: connect
      ERROR [STDERR]  at java.net.PlainSocketImpl.socketConnect(Native Method)
      ERROR [STDERR]  at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
      ERROR [STDERR]  at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
      ERROR [STDERR]  at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
      ERROR [STDERR]  at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
      ERROR [STDERR]  at java.net.Socket.connect(Socket.java:520)
      ERROR [STDERR]  at java.net.Socket.connect(Socket.java:470)
      ERROR [STDERR]  at com.sun.mail.util.SocketFetcher.createSocket(SocketFetcher.java:232)
      ERROR [STDERR]  at com.sun.mail.util.SocketFetcher.getSocket(SocketFetcher.java:189)
      ERROR [STDERR]  at com.sun.mail.smtp.SMTPTransport.openServer(SMTPTransport.java:1250)
      ERROR [STDERR]  ... 80 more
      ERROR [com.adobe.idp.Document] DOCS001: Unexpected exception. while saving null\Nico.Weyens_kindengezin.be\E-mail met bijlage (attachment): éa.pdf\090415150358\SentFiles\=?ISO-8859-1?Q?=E9a=2Epdf?=.
      java.io.FileNotFoundException: null\Nico.Weyens_kindengezin.be\E-mail met bijlage (attachment): éa.pdf\090415150358\SentFiles\=?ISO-8859-1?Q?=E9a=2Epdf?= (The filename, directory name, or volume label syntax is incorrect)
      at java.io.FileOutputStream.open(Native Method)
      at java.io.FileOutputStream.<init>(FileOutputStream.java:179)
      at com.adobe.idp.DocumentFileBackend.saveStreamToFile(DocumentFileBackend.java:374)
      at com.adobe.idp.Document.copyToFile(Document.java:1624)
      at com.adobe.idp.dsc.provider.service.email.impl.write.EmailResultHandlerImpl.handleJobSendF ailure(EmailResultHandlerImpl.java:718)
      at com.adobe.idp.dsc.provider.service.email.impl.write.EmailResultHandlerImpl.handleFailure( EmailResultHandlerImpl.java:446)
      ERROR [STDERR] com.adobe.idp.DocumentError: java.io.FileNotFoundException: null\Nico.Weyens_kindengezin.be\E-mail met bijlage (attachment): éa.pdf\090415150358\SentFiles\=?ISO-8859-1?Q?=E9a=2Epdf?= (The filename, directory name, or volume label syntax is incorrect)
      ERROR [STDERR]  at com.adobe.idp.DocumentFileBackend.saveStreamToFile(DocumentFileBackend.java:406)
      ERROR [STDERR]  at com.adobe.idp.Document.copyToFile(Document.java:1624)
      ERROR [STDERR]  at com.adobe.idp.dsc.provider.service.email.impl.write.EmailResultHandlerImpl.handleJobSendF ailure(EmailResultHandlerImpl.java:718)
      ERROR [STDERR]  at com.adobe.idp.dsc.provider.service.email.impl.write.EmailResultHandlerImpl.handleFailure( EmailResultHandlerImpl.java:446)
      ERROR [STDERR] Caused by: java.io.FileNotFoundException: null\Nico.Weyens_kindengezin.be\E-mail met bijlage (attachment): éa.pdf\090415150358\SentFiles\=?ISO-8859-1?Q?=E9a=2Epdf?= (The filename, directory name, or volume label syntax is incorrect)
      ERROR [STDERR]  at java.io.FileOutputStream.open(Native Method)
      ERROR [STDERR]  at java.io.FileOutputStream.<init>(FileOutputStream.java:179)
      ERROR [STDERR]  at com.adobe.idp.DocumentFileBackend.saveStreamToFile(DocumentFileBackend.java:374)
      ERROR [STDERR]  ... 78 more
      ERROR [com.adobe.idp.dsc.provider.service.email.impl.write.EmailResultHandlerImpl] Internal error.
