0 Replies Latest reply on Apr 16, 2009 9:14 AM by muckluck350
    Having problems with ActionScript 2 - very annoying!
      hi,
      my little character in my game has different frames for different actions, one of them being one when he's died
      however, when my character dies in the game, it stops on this frame, so if you want to play again you have to close and re-open the whole thing
      i've tried using different things such as stating that when that frame comes up, to goes to another frame (a game over one) but this usually ends up with my charcater not being able to move
      heres the actionscript for it
      (sorry about the normal writing, it was there when i copied it)
      onClipEvent (load) {
      jumping = false;
      // jumping is true
      speed = 0;
      // speed is 0
      ////Ammendment 1//
      healthX = _root.health._x;
      //sets healthX to the starting X postition of the "health" MC
      scoreX = _root.score._x;
      //sets scoreX to the starting X postition of the "score" MC
      Xpos = this._x;
      //sets Xpos to the starting X postition of this MC
      Ypos = this._y;
      //sets Ypos to the starting Y postition of this MC
      maxmove = 15;
      // maxmove is fifteen(max run seed)
      _root.maxshoottime = 50;
      // _root.maxshoottime is set to 100
      // this is how far you want the bullets to travel before deleting
      onClipEvent (enterFrame) {
      ////Ammendment 2//
      _x = Xpos-_root._x;
      //sets the X pos to the starting X postition of this MC
      _root.score._x = scoreX-_root._x;
      //sets the scire MCs X pos to its starting point on the screen
      _root.health._x = healthX-_root._x;
      //sets the health MCs X pos to its starting point on the screen
      if (!_root.ground.hitTest(this._x, this._y, true) && !jumping) {
        // if NOT hitting X and Y postion with the ground and NOT jumping
        this._y += 6;
        // Y positon moves up 6
      if (!_root.shooting) {
        // if _root.shooting is false
        _root.timer = 0;
        // _root.timer is set to 0
        _root.mvsp = _xscale/10;
        // _root.mvsp is set to the chars xscale divided by 20
        // the answer to this is the speed of the bullets
      if (_root.dead) {
        // if dead is true
        this.gotoAndPlay("dead");
        // goto and stop on the "dead" frame
      } else {
        // otherwise (if they are not dead)
        speed *= .85;
        // speed is multiplied by .85
        // the lower the faster is slows
        if (dir == "right" && !_root.leftblock.hitTest(this._x+20, this._y, true)) {
         _root.health._x += speed;
         // moves the health, the opposite way to the _root
         _root.score._x += speed;
         // moves the score, the opposite way to the _root
         this._x += speed;
         // moves the char, the opposite way to the _root
         _root._x -= speed;
         // moves the _root
        ////Ammendment 3//
        if (speed>0) {
         //if speed is smaller than 0
         dir = "right";
         // the variable dir is set to right
        } else if (speed<0) {
         //if speed is greater than 0
         dir = "left";
         // the var dir is set to left
        if (dir == "left" && !_root.rightblock.hitTest(this._x-20, this._y, true)) {
         this._x += speed;
         _root._x -= speed;
         // moves the _root
        if (Key.isDown(Key.LEFT)) {
         // if left is pressed
         if (speed>-maxmove) {
          // if the speed is greater than neg. maxmove
          speed--;
          // speed goes lower
         this.gotoAndStop("run");
         // goto and stop the run frame
         this._xscale = -100;
         // scale is set to neg. 100
         // this is what rotates ur char
        } else if (Key.isDown(Key.RIGHT)) {
         // otherwise if right is pressed
         if (speed<maxmove) {
          // if the speed is smaller than maxmove
          speed++;
          // speed goes up
         this._xscale = 100;
         // scale is set to  100
        } else if (Key.isDown(Key.CONTROL)) {
         // otherwise if control is pressed
         this.gotoAndStop("attack");
         // goto and stop the attack frame
         attacking = true;
         // attacking is true
         speed = 0;
         // speed is set to 0
        } else if (Key.isDown(Key.SPACE)) {
         // otherwise if space is pressed
         if (_root.gotgun == true && !_root.shooting) {
          // if _root.gotgun is true(they have the gun) and _root.shooting is false
          _root.attachMovie("bullet", "bulleter", 1, {_x:_root.char._x, _y:_root.char._y-25});
          // attach the movie with the Linkage name "bullet" to the _root at the character X position and the Y position minus 25
          _root.shooting = true;
          // _root.shooting is set true
          with (_root.bulleter) {
           // all code below this code and it's closer refer to _root.bulleter
           onEnterFrame = function () {
            // setting the onEnterFrame events (onClipEvent)
            if (_root.timer>_root.maxshoottime) {
             // if _root.timer is smaller than _root.maxshoottime
             _root.shooting = false;
             // shooting is false
             unloadMovie(this);
             // this movie clip is unloaded
            _root.timer++;
            // _root.timer goes up 1
            _x += _root.mvsp;
            // the X goes up _root.mvsp (which is set constantly and stays the same when shooting.)                    };
          attacking = true;
          speed = 0;
          this.gotoAndStop("shoot");
          // goto and stop on the shoot frame
        } else if (speed<1 && speed>-1 && !attacking) {
         // if speed is smaller than one and greater than neg. 1
         speed = 0;
         this.gotoAndStop("idle");
         // gotoAndStop the idle frame
        if (Key.isDown(Key.UP) && !jumping) {
         // if up is pressed and NOT jumping
         jumping = true;
         // jumping is set true
        if (jumping) {
         // if jumping is true
         this.gotoAndStop("jump");
         this._y -= jump;
         // Y position is set down jump
         jump -= .5;
         // jump is set down .5
         if (jump<0) {
          // if jump is smaller than 0
          falling = true;
          // falling is true
         if (jump<-15) {
          // if jump is smaller than neg. 5
          jump = -15;
          // jump is set to neg 5
          // capping fall speeds prevents falling through grounds
        if (_root.ground.hitTest(this._x, this._y, true) && falling) {
         // if hitting X an Y postions with the ground and falling
         jump = 12;
         // jump is set to 9
         jumping = false;
         // jumping is false
         falling = false;
         // falling is false
      onClipEvent (keyUp) {
      // on Key Up
      if (Key.getCode() == Key.CONTROL) {
        // if the release is control
        attacking = false;
        // attacking is false
      the bold part is the part i tried to change but didn't work, so at the moments it's how i copied it
      do any of you know what i could put there so it goes to another frame?
      i'll update to see if it works or not
      thanks for all your help
