10 Replies Latest reply on Aug 13, 2009 7:54 AM by wrkoch
    Datagrid to CFC
    LukeDD
      I've been waisting alot of time on this.
      I'm trying to pass and arrayCollection and pass it to a cfc. The arrayCollection is taken from a dataGrid.
      Flex Function
      private function publishToProduction(appID:Number):void{
          var devQ:ArrayCollection = dgHelpLs.dataProvider as ArrayCollection;
          roTKLib.pushToProduction.send(devQ);
      CFC function
      <cffunction name="pushToProduction">
              <cfargument name="devQ" type="any" required="yes" />
              <cfsavecontent variable="content.x">
                  <cfdump var="#arguments.devQ#">
              </cfsavecontent>
              <cffile action="write" output="#content.x#" file="#expandPath('query.html')#">
      </function>
      My problem that when the arraycollection is passed to the CFC, one it's not recognised as a query, and two is empty. Any idea what the problem might be?
        • 1. Re: Datagrid to CFC
          Michael Borbor Level 4
          Verify that the data is sent correctly from flex and in cf you acces
          the ac as myobj[1]
          Sincerely,
          Michael
          ArrayCollection;
          • 2. Re: Datagrid to CFC
            LukeDD Level 1
            Seems that my problem is that Flex is not passing the data? But Why?
            • 3. Re: Datagrid to CFC
              LukeDD Level 1
              I changed:
              var devQ:String = 'test';
              that worked so the problem is getting the data from the grid. any idea?
              • 4. Re: Datagrid to CFC
                Try passing it like this
                var devQ:ArrayCollection = new ArrayCollection(dgHelpLs.dataProvider)
                Sincerely,
                Michael
                ArrayCollection;
                • 5. Re: Datagrid to CFC
                  LukeDD Level 1
                  now getting 1118: Implicit coercion of a value with static type Object to a possibly unrelated type Array.
                  • 6. Re: Datagrid to CFC
                    EvolvedDSM Level 2
                    Can you verify that devQ is actually holding a value from your publishToProduction method?  Comment out your remoteObject command and add code to output devQ on your screen -- just to ensure there's actually data to collect and send.
                    Also, can you try removing send()?  Try using roTKLib.pushToProduction(devQ);
                    In your CFC within your cffunction and between cfargument and cfsavecontent, set up a <cfif> that checks the devQ.length EQ 0.  Something like...
                    <cfif arguments.devQ.length EQ 0>
                         <cfthrow type="conflict" message="devQ is empty">
                    <cfelse>
                         ...what you want to do with devQ...
                    </cfif>
                    I'm not 100% that arguments.devQ.length is the proper way to check the length of the argument, but you should get the idea.  The purpose of the CFIF is to return a message saying there's NOTHING stored in devQ.
                    Edited for typo's.
                    • 7. Re: Datagrid to CFC
                      LukeDD Level 1
                      AHH finally. You got me on the right track.
                      I did
                      var devQ:ArrayCollection = new ArrayCollection();
                      devQ = dgHelpLs.dataProvider as ArrayCollection;
                      And that worked like a charm.
                      Thank you Michael Borbor
                      • 8. Re: Datagrid to CFC
                        Great!
                        Sincerely,
                        Michael
                        I did
                        • 9. Re: Datagrid to CFC
                          Please close this thread.
                          • 10. Re: Datagrid to CFC
                            wrkoch
                            I've been trying to do something similar.  I did exactly the same thing.  When I interrogate the "devQ" argument in the CFC, I find it is an array of structures.  The docs imply it should be a query object.  And I need it to be a query object
                            How can I get this thing to appear in the CFC as a query object?
                            Thanks!
                            Warren Koch
