0 Replies Latest reply on Sep 10, 2008 2:46 PM by dustismo
    Bug in FABridge.js affecting Safari
    dustismo
      There is a bug in the FABridge.js when using safari. It only occurres if you are using the embed script from flexbuilder (i.e. it is added to the dom using AC_FL_RunContent)
      heres the problem:
      AC_FL_RunContent creates an 'embed' tag in some instances (like when you using safari or konqueror). FABridge only searches for 'object' tags when you are using safari:
      line 115:
      var flashInstances = document.getElementsByTagName("object");
      this is after a test to see if the browser is safari/khtml/konquerer. The problem is that
      AC_Generateobj
      generates an object ONLY when this condition is met (otherwise it is 'embed'):
      if (isIE && isWin && !isOpera)
      a hacked fix is to add this line at FABridge.js line 116
      if (flashInstances.length == 0) {
      flashInstances = document.getElementsByTagName("embed");
      but ultimately the logic in the browser testing is wrong.
      best,
      Dustin
