5 Replies Latest reply on Apr 19, 2009 3:36 PM by Jim_Simon
    Hard Disk performance & PP CS4.  Configuration ideas?
    keith204
      I experimented with HD configurations and set up a new installation of Vista Premium 64-bit.  So far I've tweaked out Vista & it runs extremely fast.  Now I'd like to figure out what HD configuration Premiere Pro CS4 likes best.
      Here's what I have running now:
      • 1x 500gb SATA drive, not very fast, and the OS is installed on it.
      • 2x 640gb 3.0g/s HD's, RAID 0 - my pagefile is on this drive, and Vista has become suddenly EXTREMELY FAST.
      • ATI Radeon HD 4850 512mb PCI x16 2.0 (surprisingly, my MB supports x16 2.0, and this is running in 2.0)
      • 4GB Ram
      • Intel Core2 Quad 9300 2.5ghz
      I have available:  1 more 640gb 3.0g/s drive that matches the other two.  These HD's are getting very cheap, and I love RAID 0 (I'll have a nightly backup running to some external drives), so I am OK with buying more HD's.
      Before I get too deep into this, I'd like to figure out the premium HD setup for rendering 5D Mark II videos.  I'll say my budget is $200 between whatever RAM/HD's I need.  Looks like I can get 8gb of RAM (4x2gb sticks) for about $100 shipped through Newegg.
      Here are a couple of ideas, but you all have more experience than I do, so tweak away:
      • HD1 (500gb non-raid) OS & Premiere Pro, HD 2&3 Raid0 - source files and pagefile, HD 4&5 Raid0 - rendering
      • HD1 (500gb non-raid) OS, HD 2&3 Raid0 - pagefile and Premiere Pro, HD 4&5 Raid0 - rendering and source files
      • HD 1&2 Raid0 - OS & Premiere Pro, HD 3&4 Raid0 - rendering & pagefile, HD5 non-raid - source files
      Anyway, I am familiar with PC configuration, but don't know much about how Premiere Pro works under the hood.  Any advice would be excellent!
        • 1. Re: Hard Disk performance & PP CS4.  Configuration ideas?
          Bill Gehrke Adobe Community Professional & MVP
          Do not waste time working with the disk system.  What you want to optimize is the CPU, get the fastest that you can but if you real want the best performance it will require an upgrade the motherboard/memory/CPU to the i7 CPU, or even better yet two of the new Xeon 5500 series processors.  This suggestion is backed by years of benchmarking Premiere.
          For your budget memory might be the only way to help.
          • 2. Re: Hard Disk performance & PP CS4.  Configuration ideas?
            Jim_Simon Level 8
            Taking Bill's advice in to consideration with regards to speed improvements, here's what I recommend for disk config:
            C:  Get a smaller hard drive and reinstall the OS/programs here.  Mine is 75GB and is only half full.  500GB is a waste as you really don't want to put anything on this drive but Windows and programs.
            D:  Current 500GB drive repurposed as a Project/Scratch drive.
            E:  Break out the RAOD 0 into separate drives, use one for Media storage only.
            F:  Use the second 650GB for Exports.
            Total cost ~ $50 for the new smaller drive.
            • 3. Re: Hard Disk performance & PP CS4.  Configuration ideas?
              Keith_Andrews Level 1
              Recommended ram installation for Premiere CS4 is 8gb for a high-performance system.  This comes direct from Adobe's white paper:
              http://www.adobe.com/products/creativesuite/production/pdfs/cs4_production_premium_64bit_w p.pdf.
              Also, I wouldn't strip down your RAID 0 so quickly.  No other hard drive configuration can achieve the transfer speed that a RAID 0 can.  I personally hit 135 MB/s with my Western Digital Raptors consistantly.  You can benchmark your drives using real video formats with AJA Video's disk drive speed test:
              http://www.aja.com/ajashare/systemtest.zip
              Furthermore, there is some advice that can be found on other popular forums that suggest running the OS with no paging file in order to force the apps to use the available ram installed in the system:
              http://www.tomshardware.com/reviews/vista-workshop,1775-6.html
              I am currently running 8GB on my Vista 64bit Ultimate setup and have my paging file set to the minimum, 16MB.  I have my OS and Premiere installation on my 75GB Raptor system drive, and my project/media on my RAID 0 Raptors.  I have been running this setup for the last month pretty heavily and have never encountered a low memory error, or system crash.
              For further help in optimizing Premiere's performance with your system take a look at the following link at Adobe's site: http://kb.adobe.com/selfservice/viewContent.do?externalId=kb405744
              • 4. Re: Hard Disk performance & PP CS4.  Configuration ideas?
                Harm Millaard Level 7
                Keith,
                When you post benchmark results, like you did from the AJA testsuite, it is beneficial to know what and how you tested. Otherwise you results are utterly meaningless. A result of transfer rate is not in the AJA test and the number 135 MB/s seems lousy in comparison to what I got with the following settings (BTW on a raid30):
                • 5. Re: Hard Disk performance & PP CS4.  Configuration ideas?
                  Jim_Simon Level 8
                  That's true, however such transfer speeds are wholly unnecessary for the camera formats typically used with Premiere.  Only in the case of Uncompressed will those kinds of disk speeds make any difference.
                  That's just really bad advice.  Windows only uses the swap file when it runs out of memory.  As expected, the article did cover the kinds of system instability that can arise without the swap file. That it didn't happen with 8GB installed only means the available RAM was not fully used, in which case the swap file would not have come into play, making the test irrelevant.
                  Here's a good analogy.  The RAM is like the gas tank in a vehicle.  The swap file is like the extra gas can in the trunk.  Normally you do all your driving using the car's tank.  Only when you run out of gas do you pull over and use the gas can.  Same with Windows.  Normally RAM is used.  Only when RAM runs out is the swap used.  And just like the motorist is stuck if there is no gas can in the trunk, so to does Windows get stuck if there's no swap file.  In the TH test, the car with a small tank (512 MB) and no gas can (swap) got stuck on the side of the road pretty frequently, while the car with the much larger tank (8 GB) and no gas can kept on running.  But this had nothing to do with the missing gas can, and everything to do with the larger gas tank.  Had they tried to use more gas than the tank would hold (use more than 8Gb of RAM at the same time), they too would have run out of gas and gotten stuck on the side of the road without that gas can.
                  The point here is always keep that gas can in your trunk, and make it as big as you can.  It won't interfere with normal driving, and is very critical to continued operation when the main tank runs out of gas.
