3 Replies Latest reply on Apr 19, 2009 9:39 AM by HyderAlamgir
    DataGrid with Array as dataProvider?
    Level 1
      I have an Array of objects to be used as a datasource for a datagrid. How do I make it work? Any help appreciated.
      Paul
      // the array
      [Bindable]
      public var arOrderItems:Array;
      // an array of these
      public class orderItem
      // make 'em public to keep it simple
      public var qty:int;
      public var code:String;
      public function orderItem()
      public function setOrderItem(q:int, c:String):void
      qty = q;
      code = c;
      // the datagrid points to the Array 'arOrderItems'
      <mx:DataGrid x="287" y="10" height="246" width="307" dataProvider="{Application.application.arOrderItems}">
      <mx:columns>
      <mx:DataGridColumn headerText="Qty" dataField="orderItem.qty" width="50"/>
      <mx:DataGridColumn headerText="Item" dataField="orderItem.code"/>
      </mx:columns>
      </mx:DataGrid>
        • 1. Re: DataGrid with Array as dataProvider?
          _Natasha_ Level 4
          // the array
          [Bindable]
          public var qty:int;
          qty = q;
          code = c;
          <mx:DataGrid x="287" y="10" height="246" width="307" dataProvider="{arOrderItems}">
          <mx:columns>
          <mx:DataGridColumn headerText="Qty" dataField="qty" width="50"/>
          <mx:DataGridColumn headerText="Item" dataField="code"/>
          </mx:columns>
          </mx:DataGrid>
          • 2. Re: DataGrid with Array as dataProvider?
            Gregory Lafrance Level 6
            Usually it is best to use an ArrayCollection as the dataProvider so you can wrap your Array in an ArrayCollection like this:
            private var myAC:ArrayCollection = new ArrayCollection(arOrderItems);
            • 3. Re: DataGrid with Array as dataProvider?
              HyderAlamgir Level 1
              The reason ArrayCollection serves you better than an Array is because ArrayColection dispatches a CollectionChange event when changes are make to it. That is also the reason Arrays are not bindable while ArrayCollections are.
