2 Replies Latest reply on Apr 23, 2009 2:55 PM by insuractive
    Webservice Result - from asp
      invoking this webservice returns this complex object - instead of the xml results expected.
      any ideas what is wrong with the ws call?  or is the problem with the 3rd party webservice?
         <cfinvokeargument name="company_id" value="1660">
         <cfinvokeargument name="type_id" value="1">
         <cfinvokeargument name="start_date" value="">
         <cfinvokeargument name="end_date" value="">
      object of com.learnlive.www.GetProgramFeedResponseGetProgramFeedResult
      Class Namecom.learnlive.www.GetProgramFeedResponseGetProgramFeedResult
      Method Return Type
      getDeserializer(java.lang.String, java.lang.Class, javax.xml.namespace.QName)org.apache.axis.encoding.Deserializer
      getSerializer(java.lang.String, java.lang.Class, javax.xml.namespace.QName)org.apache.axis.encoding.Serializer
        • 1. Re: Webservice Result - from asp
          insuractive Level 3
          My guess is your remote web service is actually returning a complex object as a response instead of a simple XML string - very common for .NET web service developers unfortunately, but a pain in the neck for us CF folks.  There are two solutions- either handle retrieving your data from the object using its built-in properties/methods (take a look at the WSDL for tips) or if you are on good terms with the web service developer, see if they can set you up with a method that does the same thing, but returns a simpe data type.
          • 2. Re: Webservice Result - from asp
            insuractive Level 3
            Actually, now that I look closer at the WSDL, I'm wonding if its the <s:any /> type of the response element that is causing issues - you might want to look into whether or not CF has problems retrieving data that has been typed to xsd:any.
