2 Replies Latest reply on Apr 20, 2009 6:31 PM by The ScareCrow
    Complex DataGrid
    The ScareCrow Level 1
      I have a complex datagrid
      The datagrid has a column that is a datagrid (ie. the itemrender is a datagrid itself.
      If anyone knows of a tutorial for this please let me know.
      Anyway it all works as expected and values are updated.
      Problem is I only want to have a single save button on the outer grid.
      I want this button to call a function to save the datagrid rows.  But as one column is a datagrid I also want it to call a function in the itemrenderer that will save the itemrenderer datagrid (make sence ?)
      Does anyone know how to call a public function of an itemRenderer from the parent component ?
      Or if I'm not doing this correctly, can you let me know !
      <mx:DataGridColumn
      dataField="
      fld_competency_id" headerText="Competency" editable="true" width="200" rendererIsEditor="true"
      itemRenderer="
      com.cfgenerated.views.renderers.PDP_Development_Competency" editorDataField="newCompentencies">
      </mx:DataGridColumn>
      Ken
        • 1. Re: Complex DataGrid
          ATIF FAROOQ Level 3
          hi,
             you can use indexToItemRenderer and itemToItemRenderer property of dataGrid to get particular ItemRenderer instance and call its public methods later on.
          • 2. Re: Complex DataGrid
            Thanks for the reply,
            I have tried this but it appears that the function is not executed.
            Some code
            The page that has the item renderer has a button with a click event that calls
            private function saveItem():void
            var pdpda:PDP_Development_Activities = this.masterList.indexToItemRenderer(2) as PDP_Development_Activities;
            pdpda.saveActivities();
            The public function in the item renderer is
            public function saveActivities():void
            Alert.show( ObjectUtil.toString('save the activities...') );
            But the alert is never shown.
            Ken
            Edit:
            This actually works if the datagrid column is column zero (0).  But as soon as I move it back it does not work.
            The datagrid has 4 columns and each column has an itemrenderer.
            So column 3 (referenced as 2) has the itemrender that is a datagrid, which is the one I need this to work on.
            Message was edited by: The ScareCrow
