6 Replies Latest reply on Apr 21, 2009 1:26 AM by dave mil
    [CS2][JS] Cell and strokeType
    dave mil
      Hello,
      I want to define the strokeType of a cell, but i don't find solution, I tried :
      myTable1.cells[0].topEdgeStrokeType = "Solid";
      myTable1.cells[0].topEdgeStrokeType = idSolid;
        • 1. Re: [CS2][JS] Cell and strokeType
          Harbs. Level 6
          You need:
          myStrokeType = app.strokeStyles.item("Solid");
          myTable1.cells[0].topEdgeStrokeType = myStrokeType;
          Harbs
          http://www.in-tools.com
          • 2. Re: [CS2][JS] Cell and strokeType
            dave mil Level 1
            I tried your solution but it doesn't work. I have an error : topEdgeStrokeType wait StrokeStyle not nothing
            • 3. Re: [CS2][JS] Cell and strokeType
              Kasyan Servetsky Level 5
              I an on CS3, but this works for me:
              var myTable1 = myDoc.stories[0].tables[0];
              • 4. Re: [CS2][JS] Cell and strokeType
                dave mil Level 1
                On CS2 version, it doesn't work
                My script :
                var myTextFrTab1 = page.textFrames.add(undefined, undefined, undefined, {geometricBounds:["20mm","15.061mm","278mm","100mm"]});
                var myTable1 = myTextFrTab1.tables.add();
                myTable1.bodyRowCount = 7;
                myTable1.columnCount = 2;
                myTable1.width = "42mm";
                myTable1.height = "277mm";
                // Fusion des cellules pour obtenir le tableau adéquate
                myTable1.cells.item(0).merge( myTable1.cells.item(1) );
                myTable1.cells.item(2).merge( myTable1.cells.item(4) );
                myTable1.cells.item(2).merge( myTable1.cells.item(5) );
                myTable1.cells.item(2).merge( myTable1.cells.item(6) );
                myTable1.cells.item(2).merge( myTable1.cells.item(7) );
                myTable1.cells.item(6).merge( myTable1.cells.item(7) );
                //Titre
                myTable1.cells.item(0).height = "12mm";
                myTable1.cells.item(0).maximumHeight = "12mm";
                myTable1.cells.item(0).width = "84.763mm";
                myTable1.cells[0].topInset = 1;
                myTable1.cells[0].bottomInset = 1;
                myTable1.cells[0].leftInset = 1;
                myTable1.cells[0].rightInset = 1;
                myTable1.cells[0].verticalJustification = VerticalJustification.centerAlign;
                //Référence
                myTable1.cells.item(1).height = "4mm";
                myTable1.cells.item(1).maximumHeight = "4mm";
                myTable1.cells.item(1).width = "25.694mm";
                //Objectif
                myTable1.cells.item(2).width = "59.217mm";
                myTable1.cells.item(2).autoGrow = true;
                //Duree
                myTable1.cells.item(3).height = "4mm";
                myTable1.cells.item(3).maximumHeight = "4mm";
                myTable1.cells.item(3).width = "25.694mm";
                //Prix
                myTable1.cells.item(4).height = "4mm";
                myTable1.cells.item(4).maximumHeight = "4mm";
                myTable1.cells.item(4).width = "25.694mm";
                //dates
                myTable1.cells.item(5).height = "4mm";
                myTable1.cells.item(5).maximumHeight = "4mm";
                myTable1.cells.item(5).width = "25.694mm";
                //Info
                myTable1.cells.item(6).width = "25.694mm";
                //Programme
                myTable1.cells.item(7).width = "59.217mm";
                myTable1.cells.item(7).autoGrow = true;
                //var aa = app.strokeStyles.item(13).id;//pointillés
                //myTable1.cells[0].topEdgeStrokeType = app.strokeStyles.item(13);
                myTable1.topEdgeStrokeType = app.strokeStyles.item(13);
                //myTable1.cells[0].topEdgeStrokeType = "Solid";
                //myTable1.cells[0].topEdgeStrokeType = app.strokeStyles.item("dotted");
                • 5. Re: [CS2][JS] Cell and strokeType
                  Harbs. Level 6
                  CS2 needs a strokeStyle. Strings don't work there.
                  I just tested the following code in CS2 and it works fine. If it
                  doesn't work for you, then you either do not have a stroke named
                  "Solid", or you do not have a proper reference to a table...
                  table=app.selection[0].tables[0];
                  strokeStyle= app.documents[0].strokeStyles.item("Solid");
                  table.cells[0].topEdgeStrokeType = strokeStyle;
                  Harbs
                  "Automated Publishing for the Rest of Us!"
                  • 6. Re: [CS2][JS] Cell and strokeType
                    dave mil Level 1
                    Ok, i have found. I must use "Pointillés" and not "Dotted".
