5 Replies Latest reply on Jun 4, 2009 11:52 AM by bustareed
    Edit field in DataGrid headers
    p.jacobi
      I'm looking for a worked out example how to have edit fields in the headers of a data grid, above the normal content (name, sort arrow).
      An approach with a separate HBox of edit fields, which resize with columns would be fine, too.
      Regards,
      Peter
        • 1. Re: Edit field in DataGrid headers
          Flex harUI Adobe Employee
          What happens if you use TextInput as your DataGrid header renderer.
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: Edit field in DataGrid headers
            p.jacobi Level 1
            If I just use TextInput as HeaderRenderer, I lose the the standard header. I don't want to replace the standard header (name and sort icon) but add to it. Or do I have to recreate this functionality, I hoped there was some kind of delegation/inheritance possible.
            (I should have stated my experience level with Flex: Nearly nil. Whereas I'm programming since the dark ages of punch cards, I just downloaded the Flex Builder Trial two weeks ago.)
            • 3. Re: Edit field in DataGrid headers
              Michael Borbor Level 4
              Just extend the DataGridHeader and add the fuctionality that you want
              Sincerely,
              Michael
              • 4. Re: Edit field in DataGrid headers
                When I set headerRenderer="mx.controls.TextInput" it showed the label of the column and shrunk to show the sort arrow.
                If you want to see some other visual, you may have to create a custom renderer.
                Alex Harui
                Flex SDK Developer
                Adobe Systems Inc.
                • 5. Re: Edit field in DataGrid headers
                  bustareed
                  I took a simple AdvancedDataGrid sample and set headerRenderer = "mx.controls.TextInput". I find that this causes the column labels to be displayed within the text input box correctly, but the sort arrows are no longer visible. Is there any other property or setting in the datagrid/advanceddatagrid that needs to be modified to make the sort arrows visible?
                  Regardless of arrow visibility, sort functionality itself appears to be working; ie clicking on the text input box toggles between ascending and descending sorting. However, the text input box loses focus immediately after it is clicked, making it impossible to enter text into it.
                  Does anyone have suggestions on how one can maintain focus on the text input box?
                  Thanks.
