7 Replies Latest reply: Apr 21, 2009 5:31 AM by Kent Jakusz RSS
    Dumb Question??
    Kent Jakusz Community Member
      I hope the philosophy here is that there is no such thing as a dumb question.
      Here goes.
      Adobe Classroom in a Book for Premier Pro states that when opening a New Project under the Project tab you have two choices DV or HDV when in actuality the choices in my version of CS4 are HDV and QuickTime.  I have been under the impression that QuickTime can be either DV or HDV and with that premise I do not understand what my choices are.
      Kent
        • 1. Re: Dumb Question??
          Andy Urtu Community Member
          Are you on a Mac?
          What is the date and version referenced in your Classroom in a book?  Sounds like it is refering to version Premiere 2.0.
          DV is dv.
          HDV is HDV ( a mpeg2 based format)
          mov is a container.  It can use many types of codecs.
          What camera are you capturing from?  That will determine what project type you should choose.
          • 2. Re: Dumb Question??
            I am on a Mac .  The book is for CS4, bran new. The option in question is in the CS4 version of Premier Pro under capture/format my options are HDV or QuickTime not HDV or DV as stated in the book.  When and why would I choose QuickTime for a capture format?  I guess if I were importing some files in QT formats but then what do I do when I want to import DV?  Is the QT option replacing DV a recent change?
            Perplexed
            Kent
            • 3. Re: Dumb Question??
              Curt Wrigley Community Member
              Its one of the few differences in the sw between platforms.   Though MAC can play an avi wrapper, it prefers quicktime.
              In Pr; HDV is a different capture mode than DV.   For example some cams can play back booth DV and HDV; so you have ot tell Pr which capture mode to be in .
              • 4. Re: Dumb Question??
                JSS1138 CommunityMVP
                My sister once called me on my home phone (a land line) and when I picked up she asked "Hey, are you home?"
                I thought that was a pretty dumb question.
                • 5. Re: Dumb Question??
                  Ann Bens CommunityMVP
                  There is no such thing as a dumb question, only dumb answers.
                  • 6. Re: Dumb Question??
                    Jeff Bellune CommunityMVP
                    Different people's brains work differently.  I am convinced that right
                    brain/left brain only scratches the surface.  What is patently obvious
                    to one is shrouded in mystery to another.
                    (And then there's the issue of *my *brain.  I've killed so many of its
                    cells over my 33+ years of adulthood that nothing is obvious anymore.)
                    People also make mistakes.  And I mean everybody.
                    -Jeff
                    • 7. Re: Dumb Question??
                      Five correct answers.  Well said, thank you.  Now how do I mark all as being correct?
                      Enjoy
                      Kent
