1 Reply Latest reply on Apr 20, 2009 7:11 PM by FONGHO
    Constant speed movement of object
    Level 1
      I am trying to get an object to track my mouse on press and i am using a tween. However, the nature of the tween is such that the time taken for the object would move would always be constant despite the distance.
      I would like to make the object travel at a constant speed regardless of the distance. Is it correct for me to use a tween? If not what should I be using?
      The code for my tween is as follows.
      map_mc.tracker_mc._x = map_mc._xmouse;
      map_mc.tracker_mc._y = map_mc._ymouse;
      startx = map_mc.crosshair_mc._x;
      endx = map_mc.tracker_mc._x;
      starty = map_mc.crosshair_mc._y;
      endy = map_mc.tracker_mc._y;
      trackTweenx = new Tween(map_mc.crosshair_mc, "_x", Regular.easeIn, startx, endx, spd, true);
      trackTweeny = new Tween(map_mc.crosshair_mc, "_y", Regular.easeIn, starty, endy, spd, true);
      map_mc.tracker_mc is the mouse cursor that would appear when onPress while the map_mc.crosshair_mc is the object that would track my cursor's movements.
      Thanks.
        • 1. Re: Constant speed movement of object
          spd = distance/time
          because you want speed constant, calculate your tween distance:
          dist=Math.sqrt((startx-endx)*(startx-endx)+(starty-endy*(starty-endy));
          and use the following time in your tween:
          time = dist/spd;
          trackTweenx = new Tween(map_mc.crosshair_mc, "_x", Regular.easeIn, startx, endx, time, true);
          trackTweeny = new Tween(map_mc.crosshair_mc, "_y", Regular.easeIn, starty, endy, time, true);
