17 Replies Latest reply on Sep 23, 2008 8:49 AM by Newsgroup_User
    SPRY - W3C Friendly?
    jon@cmiwebstudio Level 3
      tabindex="0".... this is not valid code to pass W3C standards. Do other developers just omit this or is there a workaround?
        • 1. Re: SPRY - W3C Friendly?
          Ben M Adobe Community Professional
          They have noted that some features are not W3C compliant. There is a bunch of articles over in the labs as well because I use the sort feature and spry:sort is not valid XHTML either. But there are workarounds.
          I believe you are talking about the tabbed panel because I think that is the only one that uses the tab index. I'll take a look and get back. You may also want to post this in the Spry forums to see if Adobe already has a workaround:
          http://www.adobe.com/go/labs_spry_pr1_forum
          • 2. Re: SPRY - W3C Friendly?
            sorry, forgot to mention that... it's the tabbed panel. I just omitted that part of the code since I don't think using the keyboard is that important, plus as it's coded, it doesn't work in all browsers anyway. I'll check out the labs part of the site and the other forums. Thanks for the info!
            • 3. Re: SPRY - W3C Friendly?
              Level 7
              "jon@cmiwebstudio" <webforumsuser@macromedia.com> wrote in message
              news:gb10ev$ajk$1@forums.macromedia.com...
              It's ok to use it as it helps keyboard navigation.
              Validation should be seen as a tool rather than a goal.
              Thierry
              http://www.TJKDesign.com/go/?0 | Articles and Tutorials
              http://divahtml.com/products/scripts_dreamweaver_extensions.php | Extensions
              that keep your markup clean
              http://www.fourlevel.com/ | CSS Menus, Gallery, Tab Panels, etc
              • 4. Re: SPRY - W3C Friendly?
                I will not build websites for clients that don't meet W3C standards.
                • 5. Re: SPRY - W3C Friendly?
                  Level 7
                  news:gb2bof$18b$1@forums.macromedia.com...
                  You may want to read this working draft:
                  http://www.w3.org/TR/WCAG20-TECHS/H4.html where the author refers to 0 as a
                  possible value.
                  PS: I'm curious, do you use tables or CSS for layout ?
                  Thierry
                  • 6. Re: SPRY - W3C Friendly?
                    Level 7
                    .oO(jon@cmiwebstudio)
                    I don't use Spry, so what's the actual markup that causes the error?
                    'tabindex' is valid for many elements, what does Spry do to make it
                    invalid? Can you or somebody else post some sample code or a URL?
                    Micha
                    • 7. Re: SPRY - W3C Friendly?
                      Sorry for the delay. I found the answer you are looking for:
                      http://labs.adobe.com/technologies/spry/articles/best_practices/validating_spry.html
                      The 5th paragraph down will explain your situation. The tabindex is invalid because tab indexes are only supposed to be used within Form tags as the example Thierry shows. So if you place the tabbed panels within form tags this won't be an issue. However you can remove them if you don't want users to be able to tab to them. Either way will allow your page to validate.
                      • 8. Re: SPRY - W3C Friendly?
                        Level 7
                        "Michael Fesser" <netizen@gmx.de> wrote in message
                        news:ec9ad4pk34ctgj8alsjbqmcrm9f33ie9p7@4ax.com...
                        I think it's because Spry use *0* for value
                        Thierry
                        • 9. Re: SPRY - W3C Friendly?
                          Level 7
                          .oO(Thierry)
                          0 is allowed, but it seems as if Spry assigns a tabindex to a 'div' or
                          something like that. On form elements & normal links it would be valid.
                          Micha
                          • 10. Re: SPRY - W3C Friendly?
                            Level 7
                            news:82cad49sfagikoqboj0ecvurvp8l58854c@4ax.com...
                            > .oO(Thierry)
                            That value always confused me as the spec says that "this value must be a
                            number between 0 and 32767" [1]
                            Is 0 considered being "between 0 and 32767"? I guess it is, but that's not
                            the way I read it :-(
                            Anyway, if Spry uses tabindex on DIVs it is to make these elements
                            "focusable"to help keyboard navigation, so even if it is not "kosher" it
                            could be seen as "best practice".
                            [1] http://www.w3.org/TR/html401/interact/forms.html#adef-tabindex
                            Thierry
                            • 11. Re: SPRY - W3C Friendly?
                              Level 7
                              .oO(Thierry)
                              Yes. It's like 0 <= x <= 32767 here.
                              The 0 is explicitly mentioned in the part which describes how the
                              tabbing should be done in the browser:
                              | 2. Those elements that do not support the tabindex attribute or
                              | support it and assign it a value of "0" are navigated next.
                              Micha
                              • 12. Re: SPRY - W3C Friendly?
                                Level 7
                                I wonder what that meeting was like...
                                - we really should have an upper limit on the tab order, eh?
                                - I agree. How about 40?
                                - I dunno, I could see SOMEONE putting more than 40 input fields on a page.
                                - hmm...Ok, how about 40,000?
                                - you nuts? Who would put 40,000 input fields on one page?
                                - OK, good point. Let's compromise: 32,767
                                - DONE!
                                -Darrel
                                • 13. Re: SPRY - W3C Friendly?
                                  Level 7
                                  It doesn't hurt that 32767 is an even power of 2, though.
                                  Murray --- ICQ 71997575
                                  Adobe Community Expert
                                  (If you *MUST* email me, don't LAUGH when you do so!)
                                  http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
                                  http://www.dwfaq.com - DW FAQs, Tutorials & Resources
                                  "darrel" <notreal@notreal.com> wrote in message
                                  news:gbau7p$ei8$1@forums.macromedia.com...
                                  > page.
                                  > - DONE!
                                  > -Darrel
                                  • 14. Re: SPRY - W3C Friendly?
                                    Level 7
                                    .oO(darrel)
                                    > - DONE!
                                    Actually this number has a meaning, even though it's more an
                                    implementation detail for the browser vendors. 32767 is the positive
                                    maximum that can be stored in a signed 16 bit integer variable. It
                                    wouldn't make much sense to say "between 0 and 1000" for example,
                                    because internally it would still be stored with at least 16 bit.
                                    Additionally I can imagine situations where you could use such large
                                    numbers. Firstly, tabindex applies to all types of form controls. In a
                                    long script-generated table with a lot of checkboxes or radio buttons
                                    you might need some more tabindex values. Secondly, you could also
                                    assign numbers with big steps between them (e.g. 100, 200, 300, ...) to
                                    leave room for further additions.
                                    It's usually good to have some more (number) space available than an
                                    unnecessary arbitrary restriction.
                                    Micha
                                    • 15. Re: SPRY - W3C Friendly?
                                      Level 7
                                      .oO(Murray *ACE*)
                                      That would be 32768. ;-)
                                      Micha
                                      • 16. Re: SPRY - W3C Friendly?
                                        Level 7
                                        news:fl1id4tm6nl3hptcchp4mk5vt2ubttvpta@4ax.com...
                                        > .oO(Murray *ACE*)
                                        May be Murray is talking about the number of possible values as counting 0
                                        we have 32768
                                        Thierry
                                        • 17. Re: SPRY - W3C Friendly?
                                          Level 7
                                          Yep - zero-based counting.
                                          "Thierry" <thierry@invalid.com> wrote in message
                                          news:gbb31t$k7i$1@forums.macromedia.com...
                                          >> .oO(Murray *ACE*)
                                          > we have 32768
                                          > Thierry
                                          > Extensions that keep your markup clean
