5 Replies Latest reply on Apr 21, 2009 9:43 AM by released87
    Custom Item Renderer Questions
    released87
      I am using a Custom Item Renderer with a TileList Component. I have two buttons in the Custom ItemRenderer, but cannot call methods from the button, I will get the following error:
      1180: Call to a possibly undefined method accept.
      <mx:TileList x="75" id="tile_list" dataProvider="{outputData}" columnCount="1" width="200" height="1200" backgroundAlpha="0.1" >
           <mx:itemRenderer>
                <mx:Component>
                     <mx:Box width="100" height="150" horizontalAlign="center" rollOverEffect="Glow">
                          <mx:Button label="Accept Request" click="accept()" />
                          <mx:Label text="{data.username}" />
                          <mx:Button label="Deny Request" click="deny()" />
                     </mx:Box>
                </mx:Component>
           </mx:itemRenderer>
      </mx:TileList>
      However, I will not get the error if I paste the button outside that block of code. It seems the Component cannot access the parent methods, which makes sense because it is treated as an inline sub-component. How can I work around this?
        • 1. Re: Custom Item Renderer Questions
          Gregory Lafrance Level 6
          1) The method must be public, not private.
          2) You might need to call method this way:    outerDocument.accept()
          • 2. Re: Custom Item Renderer Questions
            Michael Borbor Level 4
            Yes you're right the renderer is given its own scope you could use
            Application.application
            Sincerely,
            Michael
            El 21/04/2009, a las 10:41, released87 <forums@adobe.com> escribió:
                 <mx:itemRenderer>
                      <mx:Component>
            click="accept()" />
                           </mx:Box>
                      </mx:Component>
                 </mx:itemRenderer>
            </mx:TileList>
            • 3. Re: Custom Item Renderer Questions
              released87 Level 1
              I tried setting the method to public and it did not work. I will try targeting the parent component. How do you suggest? Should I use a parent method or target the component by name?
              • 4. Re: Custom Item Renderer Questions
                outerDocument.accept();
                outerDocument.deny();
                • 5. Re: Custom Item Renderer Questions
                  released87 Level 1
                  thank you very much
