2 Replies Latest reply on Apr 21, 2009 12:47 PM by the_wine_snob
    clips from source files...
    tmalroy Level 1
      Might be a dumb question...I have imported about a dozen different files into my project (each file is a basketball game).  I have taken each file separately, put it into the Sceneline view, and selected several scenes to keep in the sceneline and put the unwanted footage back into the project view. I essentially now have about 50 small clips in the sceneline and all of the big source files in the project view (as you can guess I am trying to make a highlight video for a basketball team).  The question now is how do I take all of those small clips in the sceneline and work with them to organize, rearrange, storyboard, etc. and move just those clips forward to making a DVD?  Everything I've tried has only let me work with the large source files, not the small clips I created from the source files.  HELP!!
        • 1. Re: clips from source files...
          Paul_LS Level 4
          Only the clips in the sceneline/Timeline view will be burnt to the DVD.
          Sorry, I am not too sure what your problem is. From what I have understood, you have created subclips in the sceneline from the larger clips in your organizer... so cut sections out of the larger clips to use in your project. With a largish project like this I would advise you to work in the Timeline mode. You will see things much more clearly, you will be able to move clips around, add effects and transitions, see the flow of the movie and see it all more clearly.
          • 2. Re: clips from source files...
            the_wine_snob Level 9
            I agree completely. What you see now are "instances" of the edited pieces from your large files. Those source files have not been physically altered, but you have representations of the pieces. In Timeline, you can do two things, that might help you see things better: 1.) adjust the Clip View. There are basically three choices to consider: show all frames, show first frame only and show first and last frame only. 2.)  You can also increase the height of the Video Track View by dragging it up. Place the cursor over the light line at the top of the Video Track in Timeline Mode. When the cursor turns into a double arrow, pointing up and down, with a bar, you can click-drag to make your Video Track taller. Might take a bit to get that double-arrow cursor, depending on your monitor's size and resolution, but it is there. One note: if you choose show all frames, your video display performance might take a hit. I usually go with show first and last frame.
            Do not delete your source files, as they are still linked and what you see is still dependant on them. If you try to delete them from your Project Panel, PE *should* warn you that they are in use and that all instances of them will also be deleted.
            In PrPro, you can create physical Sub-clips of these smaller Clips. However, until CS4, there was a major performance hit, when using Sub-clips. Unless one absolutely needs Sub-clips, working with the instances is perfectly fine, and the way it's done 99% of the time.
