9 Replies Latest reply on Nov 15, 2011 2:00 AM by Rohan Raj
    Assigning values to repeating subforms using a script
    Aditya S. Level 1
      I am using a script to add values to a repeating subform. Below is a simple example. In the real script I would use a loop to do the inserts.
      //declare XML structure
      String hrxdproot = /process_data/hrxfaform/object/data/xdp/datasets/data/form1";
      //assigning repeating subform number
      int i = 1;
      //assign a value to the first repeating subform
      patExecContext.setProcessDataStringValue(hrxdproot + "/Details[" + i +"]/employee_name", "Aditya");
      However, the error I get is
      "Target exception: org.w3c.dom.DOMException: INVALID_CHARACTER_ERR: An invalid or illegal XML character is specified. "
      I also tried to use a SetValue module to perform the same function and got the above error.
      /process_data/hrxfaform/object/data/xdp/datasets/data/form1/Details[1]/employee_name = "Aditya"
      Finally, I manually merged a sample xml (with 2 instances of the repeating subform) with the pdf and it worked fine. So I don't think there is a problem in the XML.
      Can someone please help...
