1 2 Previous Next 76 Replies Latest reply on Aug 7, 2009 10:20 AM by adriana ohlmeyer
    Canon T1i
    stevendm
      Canon is releasing a new camera next month. It is the Canon Rebel T1i. What version of Camera Raw is required to read raw files produced by this camera?
      Stevendm
        • 1. Re: Canon T1i
          Ramón G Castañeda Level 4
          If the camera has not been released, it cannot be supported by any existing version of ACR.
          Once the camera is released (actually on the shelves) you can count on the ACR Team doing its best to incorporate it in a future release of ACR, which is updated from three to four times per year.  Such a future release of ACR would be supported only in the current version of Photoshop.  The corresponding version of the stand-alone DNG Converter, which is always released in tandem with ACR, will also support the camera.  DNG files can be opened in ACR 2.4 and later versions.
          • 2. Re: Canon T1i
            stevendm Level 1
            Can I have two versions of Camera Raw installed on one computer? I will need the 4.x version for Photoshop CS3 and the upcoming 5.x for the DNG converter for the T1i?
            • 3. Re: Canon T1i
              MadManChan2000 Adobe Employee
              Steven, support for the Canon 500D (i.e., T1i) is planned for the next dot release (i.e., free update) of Camera Raw and the DNG Converter. If you have CS3 only (not CS4), then you will only need the DNG Converter. It is a standalone application and does not require the Camera Raw 5.x plug-in to function.
              • 4. Re: Canon T1i
                To emphasize what MadManChan (a most helpful member of the Adobe Camera Raw team) said, you need CS4 to run the upcoming release of (presumably) ACR 5.4, as CS3 cannot run anything later than ACR 4.6.
                The DNG Converter is a stand-alone application you use to convert the raw files from the camera to DNG files first, and then open the converted DNG files in ACR 4.6 running under.  You will need the upcoming release of the DNG Converter (again presumably 5.4), not an earlier version.
                • 5. Re: Canon T1i
                  stevendm Level 1
                  Thanks for the info.
                  I also have Lightroom 2.3. What are the steps needed to use the raw files there? Will I still need to convert to dng then use these in LR?
                  • 6. Re: Canon T1i
                    Presumably there will be a dot release update for Lightroom 2.x—eventually, following the releasse of the ACR and DNG Converter versions that will support your camera.  If Lightroom takes a little longer, then, yes you could convert your raw files to DNGs with the yet-to-be dot release of the DNG Converter.
                    Congratulations on asking all these questions BEFORE you buy the camera.
                    • 7. Re: Canon T1i
                      stevendm Level 1
                      Thank you for all of your help.
                      If I ask my questions before I buy the camera I can only be mad at myself if everything doesn't work. Otherwise I might be mad at Adobe.
                      • 8. Re: Canon T1i
                        Eggbox
                        I'd just like to add that I received my 500d (T1i) yesterday and was extremely frustrated that the CR2 RAW files don't open in CS3 or the DNG converter. I'm using the supplied 'Digital Photo Professional' to open and convert the files but, after using Bridge and Photoshop for so long, it leaves a lot to be desired. Unfortunately, it isn't possible to convert to another RAW format within the supplied software, only 8/16bit Tiff and Jpeg, but it is adequate for now.
                        Bizarrely, Bridge CS3 can read the metadata from the files just not show the actual images.
                        • 9. Re: Canon T1i
                          Unfortunately, 'tis the nature of the beast. Happens almost every time a new
                          camera comes out. We haven't seen the T1i ourselves yet so there's no way we
                          could've characterized it (e.g., for color, noise, white balance, etc.).
                          Eric
                          • 10. Re: Canon T1i
                            That's why I wrote in post #6 addressing the OP:
                            • 11. Re: Canon T1i
                              Eggbox Level 1
                              It doesn't stop you from using the camera though, or processing the RAW images, it just means that you have to do without Adobe's Camera Raw for a little while. I wouldn't have held off or bought a different camera if I'd known before hand, I'd rather have the extra time taking pics and videos than twiddling my thumbs.
                              • 12. Re: Canon T1i
                                Maybe; but in your other post you mentioned being "extremely frustrated" and sounded aggravated.
                                Due diligence research a little earlier on would have saved you the frustration and aggravation.
                                • 13. Re: Canon T1i
                                  Brooklinn28
                                  I had this same problem (unfortunately, didn't research prior to my purchase).  I ended up converting the files to jpeg through my camera software. Then you can open the saved jpeg images in Adobe Bridge and do a CTR R on Open and you at least get the RAW editor.  Not the same as having them in RAW but a much faster way to edit using Photoshop until a fix is done.
                                  • 14. Re: Canon T1i
                                    Mktgwizdotcom
                                    I am a new T1i owner and its bitter sweet to find this thread. I should have known when this happened to me when
                                    I purchased my last Canon camera. However my question is this I own the latest version of Lightroom and CS3 if
                                    and when they ACR is updated to include the T1i will I am assuming I will be able to open them in Lightroom, when
                                    I then ask LR to open the file into Photoshop I am again assuming this will work without me having to upgrade
                                    CS3? As the assumption is I would have to upgrade to CS4 wait til they update ACR for me to bring them directly
                                    into CS4?
                                    Successfully yours,
                                    George
                                    • 15. Re: Canon T1i
                                      Lightroom and Photoshop/ACR are separate. Getting the latest ACR has no
                                      impact on LR, and vice versa. If you're using LR to manage your images, you
                                      will need a LR update (not an ACR update) to get support for the 500D. That
                                      update is in progress, not out yet.
                                      Eric
                                      • 16. Re: Canon T1i
                                        Mktgwizdotcom Level 1
                                        Hello Eric
                                        Thanks for the quick response, I knew they were seperate and you have pointed out they are even more separate than I thought. So when the update does happen with Lightroom will I be able to use the "Edit in Photosop CS3 Feature" transferring my photo over to PS CS3?
                                        Successfully yours,
                                        George
                                        • 17. Re: Canon T1i
                                          Hi George, correct, that should not be an issue. Note that when you do "Edit
                                          in Photoshop CS3" what is really happening is that you are letting LR
                                          perform the raw conversion, and the rendered result of the raw conversion is
                                          then getting passed to PS. (That is, you are not passing the raw data over
                                          to PS to let PS/ACR perform the raw conversion.)
                                          Eric
                                          • 18. Re: Canon T1i
                                            Hello Eric
                                            Great that is what I thought was happening when using that feature but have learned not to assume : ) Any speculation
                                            as of a date LR will have an update?
                                            Successfully yours,
                                            George
                                            • 19. Re: Canon T1i
                                              landlex
                                              I have stumbled on to a work-around until Camera RAW is updated by Adobe.
                                              1.  Open the image in Canon's Digitial Photo Pro.
                                              2   In DPP, go to the edit screen.
                                              3.  Under "Tools", choose "transfer to Photoshop".
                                              4.  In CS4, Photoshop opens the image as a .tif file.
                                              You could edit in DPP and then transfer, or do all your editing in Photoshop.
                                              Good luck!
                                              • 20. Re: Canon T1i
                                                genebromberg
                                                I'd also like to ask when we might see an update to Lightroom 2.3 that allows me to download RAW files from my brand-spankin' new T1i. And, would it expedite matters if I said "Please"? How about "Pretty Please"? I'm prepared to go all the way to "with sugar on top" if that's what it takes.
                                                • 21. Re: Canon T1i
                                                  John Joslin Level 6
                                                  Look at it this way.  ACR and Lightroom teams are each working on an update cycle which is governed by their resources; and each update normally includes bug fixes, feature improvements and changes to accommodate new cameras on which they have sufficient data. At the same time a dozen or so camera manufacturers are beavering away at their latest and greatest model.
                                                  Do you really think it is feasible for the software teams to suddenly say "Hey look! There is a new Canon out – let's drop everything; buy and test the new camera; analyse the data, and whip out a new version of our software to process it."
                                                  Not really on is it?
                                                  • 22. Re: Canon T1i
                                                    JJ is right, but you can also look at it this way:
                                                    What would you do if the answer to your question was "within a year or two" ?  You have the camera already, presumably it came with software to convert its raw files.  Would you sell it and buy a different model which is already supported?
                                                    Continuing to ask "are we there yet" won't make ACR support for your camera materialize any sooner.  It'll be released when it's ready.
                                                    • 23. Re: Canon T1i
                                                      genebromberg Level 1
                                                      Well, I'm not whining "Are we there yet?", just if anyone knows approximately when we might expect an update. I've never bought a brand-new model before, hence my question. Are the updates released at set times during the year, or as they come available? I see there was an update for seven cameras in December, just wondering if there's a reasonable ballpark estimate as to when the new Rebel might be supported. Until then I'll use Canon's software and whistle a happy tune.
                                                      • 24. Re: Canon T1i
                                                        There are three to four orderly releases of ACR and the DNG Converter per year.  The last one was in February.
                                                        There are no guarantees as to whether a given camera will make the next release or not.
                                                        Lightroom releases appear to have a release program of their own, usually very soon after ACR.  The LR release you linked to was not the latest one, by the way.
                                                        Are you any better off knowing this?
                                                        • 25. Re: Canon T1i
                                                          Indubitably.
                                                          • 26. Re: Canon T1i
                                                            Eggbox Level 1
                                                            Just to throw in my 2c again....
                                                            The camera has been in the hands of reviewers for months, I'd be amazed if Canon didn't let Adobe have a model at the same time so that they could work on the Camera Raw update. It's not much of an excuse to say that the update hasn't been created because the camera has only just been released...Does an Adobe staff member have to physically buy every camera when it's released and not a moment earlier?
                                                            Back on topic...
                                                            I'm archiving the photo's as 16bit Tiffs which offers the same bit-depth as the RAW files, allowing exposure tweaking further down the line in Photoshop if required. If I had something really precious I'd just save the RAW file but, so far, I haven't needed to do much tweaking...the camera takes great photos.
                                                            • 27. Re: Canon T1i
                                                              PECourtejoie Adobe Community Professional
                                                              There is another solution: Adobe (by the work of Thomas Knoll and the ACR team) have created the DNG format, and have an SDK ready.
                                                              Canon could use that format alongside their CR2 format, like Pentax is doing. Had they chosen this way, Lightroom, Camera Raw, and other raw converters could have opened the files on the very first day of the release of the camera!
                                                              • 28. Re: Canon T1i
        Well Eggbox, I guess it's time for you to be amazed.
        In general, yes, Adobe does get early camera samples from camera makers.
        This helps us to add camera support in a more timely fashion, so updates get
        out to our users sooner. Unfortunately, in the case of the 500D/T1i, Adobe
        has not yet received any loaner/preproduction/review sample from Canon.
        (Adobe != reviewer.) Frankly, there is nothing Adobe can do about that.
        One workaround is for us to buy a unit when it ships. But that introduces a
        significant delay, and the cameras don't ship in all countries at the same
        time. (I believe the 500D/T1i only recently started shipping in the USA, for
        example.)
        We really do want to add support for new cameras and get the release out to
        you as soon as we can, but sometimes there really are things beyond our
        control.
        Eric
        • 29. Re: Canon T1i
        Wow, that's just nuts. The only semi-rational explanation I can come up with for Canon not zipping you one of the first cameras off the assembly line is that they want people using THEIR software instead of Photoshop/Lightroom, so they don't want to help what they see as their competitor. With all due respect to the fine people at Canon, if that's their attitude they're flat-out loco. It's just jaw-dropping that if Adobe wants to modify their software so Canon shooters can import RAW files from their new camera, someone first has to order the camera from Amazon or drive down to Best Buy.
        • 30. Re: Canon T1i
        JimHess-8IPblY Level 3
        Congratulations!  You are beginning to understand the dilemma facing raw photographers.  Each camera manufacturer has their own proprietary raw format with raw software designed to enable you to edit that image.  They are not concerned with Photoshop or camera raw or Lightroom or any other "third party" raw converter.  That's why they have proprietary fields in their exif data.  Lightroom, ACR and other raw converters cannot read that information, and it's that way by design.  These companies cannot stop Adobe from supporting the camera, and creating profiles to emulate those proprietary settings, but they can prevent Adobe and others from reading that data directly.  It's not in the best interests of the photographer.  It's in the best interest of the company.  And therein lies the issue surrounding raw support.
        • 31. Re: Canon T1i
        I knew every company had it's own RAW format, just not that they were THAT opposed to others duplicating that format to provide ease of use. I thought it was more a technical issue than a proprietary one. I'm sure this is a point that's been raised before, but this doesn't seem to make much sense from Canon's point of view. They want to sell cameras, but if you're thinking of upgrading and know that for months you won't be able to use your preferred software to read the RAW files you might put off that purchase. Or look at a competing camera that already has that support. Seems a bit short-sighted, as that course of action prevents your customer from fully enjoying your product's abilities, keeps those customers from developing an even deeper attachment to your brand, perhaps spurs your customers to write frustrated, whiny posts on another company's forums, etc.
        • 32. Re: Canon T1i
        From the photographer/customer point of view, everything you say makes perfect sense.  It has been suggested by others on this forum that one should check before they purchase a camera to make sure it is supported.  And the argument against that is that that should never have to be a consideration.  Unfortunately it is.  This "turf" attitude is one of the main things that motivated the Adobe to develop the DNG (Digital negative) format in an attempt to "standardize" the raw format.  But even to do that, Adobe has to be able to create a profile for each specific camera.  Pentax, as far as I know, is the only camera manufacturer that has adopted the DNG format that as an alternative raw format.  With their digital SLRs it is possible to choose between the native raw format and the DNG format.  New users can choose the DNG format and have immediate support for their raw images, newest models.  Other manufacturers apparently haven't shown any interest in doing this.  The problem doesn't bother me anymore.  I have one of those old-fashioned Nikon D40 cameras that has been supported for quite some time.  But we read the frustration from people, just like you, whenever a new camera is introduced and they want immediate support.  One good thing going for you, Canon (as I understand it) provides you with their software free when you purchase a camera.  Nikon, on the other hand, charges nearly $200 for their premier software for working with the raw images.  They do provide a very basic raw convertor package, but it's painfully slow and noticeably lacking in features.
        • 33. Re: Canon T1i
        FYI, many cameras that support DNG will also embed camera color profiles in
        the DNG itself (e.g., recent Casio, Ricoh, and Pentax cameras). Adobe does
        not need to create color profiles for such cameras. The profile simply
        "comes with the DNG" so to speak.
        Eric
        • 34. Re: Canon T1i
        Jeff Schewe Level 5
        Actually, every camera model is in effect its own raw file format which must be individually decoded by 3rd parties–and even the camera companies' own software updated to handle new cameras...which indeed is stooopid.
        The fact is that the camera companies still delude themselves that the raw file format somehow has some sort of proprietary value. It doesn't...but they just don't believe that. They think their own raw file format, since they have to spend so much of their own resources developing them, must be worth keeping secret. But, the only real secret with regards to raw file formats is that there really aren't any secrets. Anything they can encode in a raw file format can be decoded by others–legally. It's not like Canon has a patent on their CR2 or Nikon on their NEF...both of who are derived from the ISO standard TIFF-EP (Electronic Photography) which is based on TIFF 6 which is owned by Adobe...and DNG is a further specified TIFF-EP spec.
        The camera companies would be better served spending their time and money more wisely rather than wasting their resources making their own raw file formats...and with the downturn in the global economy it might make sense for them to re-evaluate DNG. Adobe has already submitted DNG to the ISO for the next update of TIFF-EP. So, if that happens, it'll remove one barrier the camera companies have been using against DNG...the fact that the spec is owned by Adobe.
        And, the thing of it is, if they DID adopt DNG, it would eliminate this crap about waiting for software updates and make their own software support easier to implement.
        • 35. Re: Canon T1i
        ssprengel Adobe Community Professional & MVP
        My brother had his hands on a retail copy of a T1i in Toronto over a week
        ago, already.
        • 36. Re: Canon T1i
        Jeff Schewe Level 5
        ago, already.
        Uh huh...and you expect Adobe to turn the update around how fast?
        Give me a break...we're talking quarters here, not days or weeks...
        You want Adobe to be able to support camera when they come out? Talk to Nikon and Canon...
        Jeeesh...aren't you paying attention?
        • 37. Re: Canon T1i
        In defense of why Adobe had not released support, yet, someone said Adobe
        didn't have one, yet.   I merely said they are available, now.  I agree
        Canon should have given you one long ago, but now that they're out, Adobe
        still not having one seems wrong if that was the insider information being
        communicated.
        "Quarters" (plural) suggests more than one 3-month period, with the minimum
        being 2 quarters, or a 6-month turn around time.  I guess I wouldn't have
        thought it takes that long to profile a new sensor, compute the NR
        coefficients for various ISOs, and beta test those things, especially with a
        new camera model every 12 months or so, nowadays.  Canon, themselves, has
        chopped 6 months off their release cycle to keep up with the competition's
        features, so a camera was probably not available for them to give 6 months
        ago.
        How long does it actually take Adobe from receipt to being ready to release
        support for a new model?  I would expect that sometimes the main delay would
        be syncing up with the next ACR or LR release that could have additional
        features that would take quite a few months to code and test and re-test,
        but adding a new camera model can't be that hard unless it is a completely
        new sort of decoding algorithm or the manufacturer is requiring
        lens-distortion or custom NR built-in.
        People shouldn't be whining about not having support, immediately, if Adobe
        had no access to the hardware, as if it's Adobe's fault, but expecting a
        camera quarters in advance seems too demanding.  I suppose Canon may have
        been trying to help out the noise in the ISO128000 end of things right up
        until the end so they may not have been able to give out anything for Adobe
        until literally weeks ago when the camera was almost out, anyway.
        Hopefully there isn't some war of words between Adobe/DNG and others/RAW
        where each tries to bad-mouth the other than drag their feet to make things
        bad for the other.
        Personally, I am waiting for the 60D in the fall which Adobe would hopefully
        support by a couple months afterwards.
        • 38. Re: Canon T1i
        What you seem to be missing is a grasp of the concept that Adobe releases three to four versions of ACR per year in an orderly fashion.  Don't expect a new release just because a new camera is released to the market.  That will just not happen.
        • 39. Re: Canon T1i
        Eggbox Level 1
        Well MadManChan2000 I'm amazed
        I don't see it as a purposely awkward move by Canon against Adobe, like they're trying to prevent people using Photoshop, because it's not in their interests as a camera manufacturer and I also doubt that they would include a 'send to Photoshop' function in their software. It is, however, pretty rediculous and I'm amazed that nobody has pointed this out to Canon...or perhaps they have?
        Thanks for your input MadManChan2000...interesting stuff
        1 2 Previous Next
