3 Replies Latest reply on Apr 22, 2009 8:54 AM by Steve Zeeeee
    Suddenly frame rate has no effect
    Steve Zeeeee Level 1
      Can some one give me a clue what to do?
      Sudddenly, my dissolve stops working correctly.
      The first dissolve works right, but the 2d one just creeps along.
      8 frames at 24/sec should tke 1/3 second, but it takes way longer.
      Even if I change the frame rate, the effect does not change.
      It used to work.  The picture fade-in is crappy.
      you can see it here; click on the right side to activate the event.
      Thanks anyone.
      http://www.stevezavodny.com/blogs/June07/June07.htm
      Flash CS3, AS 2, OSX.4.11
