3 Replies Latest reply on Nov 3, 2010 1:20 PM by brock.haywood
    Porting GoogleMapUtility to AS3
    HyderAlamgir
      I couldn't find anyone having ported the GoogleMapUtility to AS3 from PHP... so I tried my hand at it.
      I ended up with an internal build error. Love those, don't you!
      I've hosted the code here
      http://code.google.com/p/google-map-utility-as3/source/browse/trunk/GoogleMapUtility.as
      The original PHP can be found here:
      http://uwmike.com/maps/GoogleMapUtility.php.source
      Could someone do a quick review and see where I may be screwing up.
      For instance, I don't where some variables need to be declared. PHP's loose coding is a mess to port out.
      Keep in mind, that I'm no AS3 genius, and I absolutely suck at math.
        • 1. Re: Porting GoogleMapUtility to AS3
          HyderAlamgir Level 1
          Ok, no answers yet.
          In any case, I've fixed the internal build error.
          Now, the calculations are all messed up. I get different results from calling the PHP function and different ones from calling the ported function in AS3.
          Anyone?!
          • 2. Re: Porting GoogleMapUtility to AS3
            _Natasha_ Level 4
            It's will bw easier to help if you write call parameters for functions and results for AS and PHP
            • 3. Re: Porting GoogleMapUtility to AS3
              brock.haywood
              You have errors in your rad2deg and deg2rad methods.
              Here is the fixed class:
              package com.google.maps
              import flash.geom.Point;
              import flash.geom.Rectangle;
              public class GoogleMapsUtility
              public static const TILE_SIZE:int = 256;
              public static var normalised:Point = new Point(-1, -1);
              public static var pixelCoords:Point;
              public static var scale:Number = 1;
              public static function fromXYToLatLng( point:Point, zoom:int ):Point
              scale = ( 1 << (zoom)) * GoogleMapsUtility.TILE_SIZE;
              // CORRECT: Where does normalised come from?! //
              return new Point( int( GoogleMapsUtility.normalised.x * scale), int( GoogleMapsUtility.normalised.y * scale) );
              return new Point( pixelCoords.x % GoogleMapsUtility.TILE_SIZE,
              pixelCoords.y % GoogleMapsUtility.TILE_SIZE );
              public static function fromMercatorCoords( point:Point ):Point
              point.x *= 360;
              point.y = GoogleMapsUtility.rad2deg( Math.atan( GoogleMapsUtility.sinh( point.y )) * Math.PI );
              return point;
              public static function sinh( x:Number ):Number
              return ((Math.exp(x) - Math.exp(-x)) / 2.0);
              public static function rad2deg( rad:Number ):Number
              return (rad * 180 / Math.PI);
              public static function deg2rad( deg:Number ):Number
              return (deg * Math.PI / 180);
              public static function getPixelOffsetInTile( lat:Number, lng:Number, zoom:Number ):Point
              pixelCoords = GoogleMapsUtility.toZoomedPixelCoords( lat, lng, zoom);
              public static function getTerminalPixelOffsetInTile( lat:Number, lng:Number, zoom:Number,
              rot:Number, len:Number ):Point
              var endlng:Number = lng + ( len / ( 3 * 9500 )) * Math.cos( GoogleMapsUtility.deg2rad( rot ));
              var endlat:Number = lat + ( len / ( 3 * 9500 )) * Math.sin( GoogleMapsUtility.deg2rad( rot ));
              var newpt:Point = GoogleMapsUtility.getPixelOffsetInTile( endlng, endlat, zoom );
              return newpt;
              public static function getTileRect( x:Number, y:Number, zoom:Number ):Rectangle
              // CORRECT: What types to use here -- Number?
              var tilesAtThisZoom:Number = 1 << zoom;
              var lngWidth:Number = 360.0 / tilesAtThisZoom;
              var lng:Number = -180 + ( x *  lngWidth );
              var latHeight:Number = 2.0 / tilesAtThisZoom;
              var lat:Number = (( tilesAtThisZoom / 2 - y - 1 ) * latHeight );
              /** convert lat and latHeight to degrees in a transverse mercator projection
              * note that in fact the coordinates go from about -85 to +85 not -90 to 90! */
              latHeight += lat;
              latHeight = ( 2 * Math.atan( Math.exp( Math.PI * latHeight ))) - ( Math.PI / 2 );
              latHeight *= ( 180 / Math.PI );
              lat = ( 2 * Math.atan( Math.exp( Math.PI * lat ))) - ( Math.PI / 2 );
              lat *= ( 180 / Math.PI );
              latHeight -= lat;
              if ( lngWidth < 0 )
              lng = lng + lngWidth;
              lngWidth = -lngWidth;
              if ( latHeight < 0 )
              lat = lat + latHeight;
              latHeight = -latHeight;
              $latHeightMerc = 1.0 / $tilesAtThisZoom;
              $topLatMerc = $y * $latHeightMerc;
              $bottomLatMerc = $topLatMerc + $latHeightMerc;
              $bottomLat = (180 / M_PI) * ((2 * atan(exp(M_PI *
              (1 - (2 * $bottomLatMerc))))) - (M_PI / 2));
              $topLat = (180 / M_PI) * ((2 * atan(exp(M_PI *
              (1 - (2 * $topLatMerc))))) - (M_PI / 2));
              $latHeight = $topLat - $bottomLat;
              return new Rectangle( lng, lat, lngWidth, latHeight );
              public static function toMercatorCoords( lat:Number, lng:Number ):Point
              if ( lng > 180 ) {
              lng -= 360;
              lng /= 360;
              lat = GoogleMapsUtility.invhypsin( Math.tan( GoogleMapsUtility.deg2rad( lat ))) / Math.PI/2;
              /**$lat = 0.5 - ((log(tan((M_PI / 4) + ((0.5 * M_PI * $lat) / 180))) / M_PI) / 2.0);*/
              return new Point( lng, lat );
              public static function toNormalisedMercatorCoords( point:Point, z:Number ):Point
              point.x += 0.5;
              point.x *= z ^ 2;
              point.y = Math.abs( point.y - 0.5 );
              point.y *= z^2;
              return point;
              public static function toZoomedPixelCoords( lat:Number, lng:Number, zoom:int ):Point
              var pt:Point;
              pt = GoogleMapsUtility.toNormalisedMercatorCoords(
              GoogleMapsUtility.toMercatorCoords( lat,  lng ), zoom );
              GoogleMapsUtility.normalised.x = pt.x;
              GoogleMapsUtility.normalised.y = pt.y;
              GoogleMapsUtility.scale = ( 1 << ( zoom )) * GoogleMapsUtility.TILE_SIZE;
              return new Point( int( GoogleMapsUtility.normalised.x * GoogleMapsUtility.scale ), int( GoogleMapsUtility.normalised.y * scale ));
              public static function invhypsin( z:Number ):Number {
              return Math.log( z + Math.sqrt( z^2 + 1 ));
