9 Replies Latest reply on May 18, 2009 7:56 PM by Cliff Gordon
    exporting 16:9 movie
    Cliff Gordon
      I have a project I'm having problems with...I shot SD 16:9 with a Sony D30sw on DVCAM. I opened a 16:9 project and imported the footage. Everything imports correctly. I edit my sequence and export as a DV avi. It opens with media player and plays perfectly 16:9, full frame, no letterbox. I bring this file into Squeeze so I can compress it for web delivery. The file I get is 4:3 letterboxed...I've tried to force 19:9 aspect ratio sizes. No change. I just want a full frame 16:9 compressed file, not letterboxed. What am I missing??? Thanks
        • 1. Re: exporting 16:9 movie
          Jim_Simon Level 8
          My guess would be this is a problem with Squeeze.
          • 2. Re: exporting 16:9 movie
            Cliff Gordon Level 1
            Jeff,
            Thanks for the reply. I have the same issue even if I export it directly
            form CS3...Somehow it seems to be losing it's PAR info...
            Cliff
            • 3. Re: exporting 16:9 movie
              Eddie Lotter Level 4
              I have the same issue even if I export it directly form CS3...Somehow it seems to be losing it's PAR info...
              That contradicts what you posted originally. Please post more details.
              Cheers
              Eddie
              • 4. Re: exporting 16:9 movie
                Sorry, I should have been more clear.
                I've tried to export a compressed version (QuickTime h264 and wmv 768k
                stream) directly from CS3 and get similar results. I can force a 16:9 file
                but the video is pillar boxed, squashed and does not fill the frame...much
                like the 4:3 version I'm getting from Sorenson.
                Cliff
                • 5. Re: exporting 16:9 movie
                  Jim_Simon Level 8
                  Correct playback of anamorphic files often needs to be manually adjusted in the playback software.  Quicktime and Windows Media Player do not easily handle this task.  Best to use the KMPlayer, VLC or even GOM player.  See if one of those helps.
                  • 6. Re: exporting 16:9 movie
                    Thank you Jim. I'll try out those players. Windows Media Player seems to
                    figure it out. It's Quicktime that is giving me fits...
                    Cliff
                    • 7. Re: exporting 16:9 movie
                      Jim_Simon Level 8
                      That's not surprising, and is just one of many reasons why I don't have any version of Quicktime installed on any of three computers.
                      • 8. Re: exporting 16:9 movie
                        mmckee58 Level 1
                        I've decided to keep life simple, that the players should only deal with square pixels, so here's my method for doing 16:9.
                        In my case I capture HDV which has a 1.333 PAR, a rectagular pixel.
                        After I capture, I select the file, and go to File-Interpret Footage, and select square pixels.  Now my source footage looks all squeezed up in the preview window.  I edit as usual, but I add a Transform filter in the timeline, scale height = 100%, and can you guess the scale width value?  That's right 133.3%
                        Now I have a 16:9, square pixel output and I select a 16:9 output dimension, like 520 wide by 292 high.
                        Works like a champ, without having to use silly hd codecs or anamorphic mumbo jumbo.
                        I use it for Flash delivery and I use it for podcasting apps as well.
                        Hope that helps!
                        Mark
                        • 9. Re: exporting 16:9 movie
                          Mark,
                          Thank you for your reply. That's the best solution I've gotten so far. I
                          just had another situation where your trick would have worked for me...I
                          recently opened a project using the default 16:9 DV settings. I imported
                          BetaSP through my BlackMagic video card. The footage was shot 16:9 SD.
                          Premiere recognized it and scaled the video to the proper 16:9 size.
                          Unfortunately the captured footage acquired weird "sparkles", some kind of
                          digital artifacts. I was on a tight deadline to finish the video, it was a
                          56 minute infomercial, so I ignored the problem until I was done with the
                          edit. I tried every setting I could imagine, recaptured, spit, swore...but
                          nothing removed the sparkles. Sooooo, I opened a new project using the
                          BlackMagic 8bit uncompressed settings like I should have in the first place.
                          I imported the DV project into the new one and recaptured all the footage.
                          Viola, no sparkles! The only problem was Premiere didn't rescale the footage
                          as it had in the DV project. It played pillar boxed 4:3 in this new 16:9
                          project. I kind of eyeballed it and scaled the width to 136% and the world
                          was a better place to live...Next time I'll use the 133.3% width and see how
                          it looks.
                          Sorry for the long story and thanks again for the solution!
                          Cliff
